3rd Gen Technical Service Bulletins
Status
Not open for further replies.
L
lilfroger
5.9 CTD
TSB 2200506: Front end Shimmy
Service bulletin #: 2200506
replacement sb#:
Nhtsa item #: 10020919
date: 20061007
failing component: 190000 tires
make: Dodge
model: Ram
year: 2003, 2004, 2005, 2006, 2007
date created: 20070130
description of summary: Front end shimmy on 4x4 vehicles when traveling over rough surfaces in the road. *kb
L
lilfroger
5.9 CTD
Tsb 804406: Dtc c1240
Service bulletin #: 0804406
replacement sb#:
Nhtsa item #: 10020925
date: 20061007
failing component: 110000 electrical system
make: Dodge
model: Ram 3500
year: 2007
description of summary: Diagnostic trouble code (dtc) c1240, steering angle sensor over travel performance. *kb
L
lilfroger
5.9 CTD
Tsb 2100206 : Dtc p1713/p1776
Service bulletin #: 2100206
replacement sb#: 2100206a
nhtsa item #: 10020935
date: 20061209
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2006
date created: 20070201
description of summary: Flash 42rle - improved hill climb capability in reverse or diagnostic trouble codes (dtc) p1713/p1776. *kb
L
lilfroger
5.9 CTD
Tsb 1803206: Dtc p0191
Service bulletin #: 1803206
replacement sb#:
Nhtsa item #: 10020946
date: 20061102
failing component: 070000 fuel system, diesel
make: Dodge
model: Ram
year: 2006, 2007
date created: 2006
description of summary: 5.9l dtc p0191 - fuel pressure sensor rationality. Erase and reprogram the powertrain control module (pcm) with new software. *kb
L
lilfroger
5.9 CTD
Tsb 0200107: When braking may drift or exhibit a shudder
Service bulletin #: 0200107
replacement sb#:
Nhtsa item #: 10021090
date: 20070120
failing component: 020000 suspension
make: Dodge
model: Ram
year: 2006
date created: 20070301
description of summary: When braking the vehicle may drift to one side or exhibit a body shudder. *kb
L
lilfroger
5.9 CTD
Tsb 1800107: Dtc p2502, p2503, or p2509
Service bulletin #: 1800107
replacement sb#:
Nhtsa item #: 10021092
date: 20070106
failing component: 112000 electrical system:alternator/generator/regulator
make: Dodge
model: Ram 2500, 3500
year: 2006, 2007
description of summary: Check gauges lamp illuminates for alternator charging with dtc p2502, p2503, or p2509. *kb
L
lilfroger
5.9 CTD
Tsb 0600107: Clutch system may over-adjust
Service bulletin #: 0600107
replacement sb#:
Nhtsa item #: 10021211
date: 20070203
failing component: 102000 power train:manual transmission
make: Dodge
year: 2007
date created: 20070322
description of summary: Clutch system may over-adjust causing difficulty engaging transmission gear. *kb
L
lilfroger
5.9 CTD
TSB 0803006: PCM Initialization
Service bulletin #: 0803006
replacement sb#: 0803006a
nhtsa item #: 10021239
date: 20060825
make: Dodge
model: Ram
date created: 20070323
description of summary: Powertrain control module initialization. *kb
L
lilfroger
5.9 CTD
Tsb 0900107: Throttle body joint may cause a whistle
Service bulletin #: 0900107
replacement sb#:
Nhtsa item #: 10021422
date: 20070314
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
year: 2007
date created: 20070425
description of summary: Intake - to - throttle body joint may cause a whistle - like sound on 3.7l engines. *kb
L
lilfroger
5.9 CTD
Tsb 1802207: Diesel engine system enhancements
Service bulletin #: 1802207
replacement sb#:
Nhtsa item #: 10021423
date: 20070314
failing component: 061120 engine and engine cooling:engine: Diesel: Turbo-charger
make: Dodge
model: Ram
description of summary: 5.9l turbo - diesel engine system enhancements. *kb
L
lilfroger
5.9 CTD
Tsb 2100507 : Dtc's p1713 / p1776
Service bulletin #: 2100507
replacement sb#:
Nhtsa item #: 10021426
date: 20070320
make: Dodge
model: Ram
year: 2006
description of summary: Improved hill climb capability in reverse or dtc's p1713 / p1776. *kb
L
lilfroger
5.9 CTD
Tsb 2100607: Full disable of 4th gear overdrive
Service bulletin #: 2100607
replacement sb#:
Nhtsa item #: 10021427
date: 20070320
make: Dodge
model: Ram
year: 2005
description of summary: New 48re feature that allows normal shift schedule with full disable of 4th gear overdrive. *kb
L
lilfroger
5.9 CTD
TSB 1802907: Generic PCM Procedure
Service bulletin #: 1802907
replacement sb#:
Nhtsa item #: 10021684
date: 20070426
failing component: 103100 power train:automatic transmission:control module (tcm, pcm)
make: Dodge
model: Ram
year: 2004, 2005
date created: 20070615
description of summary: Generic powertrain control module (pcm) procedure. *kb
L
lilfroger
5.9 CTD
TSB 1803007: Diesel Off-Idle Speed Limitation
SERVICE BULLETIN #: 1803007
REPLACEMENT SB#:
NHTSA ITEM #: 10021685
DATE: 20070426
FAILING COMPONENT: 061000 ENGINE AND ENGINE COOLING:ENGINE
MAKE: DODGE
MODEL: RAM
YEAR: 2004, 2005, 2006, 2007
DATE CREATED: 20070615
DESCRIPTION OF SUMMARY: ENGINE OFF-IDLE SPEED LIMIT FEATURE TO PROTECT TURBOCHARGER WHEN VEHICLE IS NOT MOVING. *KB
Discussion:
Dependent upon engine coolant temperature, the Engine Control Module (ECM) will temporarily delay (limit) the maximum engine speed when the vehicle is not moving. For automatic transmission equipped vehicles, the maximum engine speed is temporarily delayed when the vehicle speed is less than one mph, and when the transmission selector is in either the neutral or park position. For manual transmission equipped vehicles, the maximum engine speed is temporarily delayed when the vehicle speed is less than one mph. This ECM feature is used to protect the engine turbocharger.
By temporarily limiting the vehicle engine speed, the shaft speed of the engine turbocharger is controlled to a low speed. This delay in maximum engine and turbo-charger shaft speed allows for sufficient oil lubrication to the turbocharger shaft bearings. Satisfactory oil lubrication of the turbocharger shaft bearings is important for long term turbocharger durability.
The maximum engine speed for the 5.9L engine is temporarily limited to 1,600 RPM's when the above conditions are met. The 6.7L engine speed is temporally limited to 1,200 RPM's when the above conditions are met. The length of time that the maximum engine speed is temporarily limited is dependent upon engine coolant temperature. Refer to the table to determine the amount of Time Delay.
NOTE: The time delay values supplied in the table are an approximation and may vary per application.
ENGINE TEMPERATURE TIME DELAY
- 35° F 45.2 secs.
- 20° F 34.6 secs.
- 10° F 28.8 secs.
- 0° F 24.2 secs.
+ 10° F 20.2 secs.
+ 20° F 17.0 secs.
+ 35° F 13.0 secs.
+ 45° F 10.8 secs.
+ 55° F 9.0 secs.
+ 70° F 7.0 secs.
L
lilfroger
5.9 CTD
Tsb 1802707 : Dtc - p0404, p0405, p0406
SERVICE BULLETIN #: 1802707
REPLACEMENT SB#:
NHTSA ITEM #: 10021686
DATE: 20070417
MAKE: DODGE
MODEL: RAM
YEAR: 2006, 2007
DESCRIPTION OF SUMMARY: MIL ILLUMINATION DUE TO EGR POSITION SENSOR DTC - P0404, P0405, P0406. *KB
NOTE: This bulletin applies to vehicles equipped with a 5.7L engine with MDS
(sales code EZB) built on or before February 15, 2007 (MDH 0215XX).
L
lilfroger
5.9 CTD
Tsb 2301307: Mirror glass locking tab - new removal procedure
Service bulletin #: 2301307
replacement sb#:
Nhtsa item #: 10021687
date: 20070413
failing component: 980000 unknown or other
make: Dodge
model: Ram
description of summary: Trailer towing mirror - new mirror glass locking tab - new removal procedure. *kb
L
lilfroger
5.9 CTD
Tsb 1803307: Excessive soot accumulation in exhaust
SERVICE BULLETIN #: 1803307
REPLACEMENT SB#: 18-013-08
NHTSA ITEM #: 10021981
DATE: 20080313
FAILING COMPONENT: 103100 POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
MAKE: DODGE
MODEL: RAM 2500, 3500
YEAR: 2007, 2008
DATE CREATED: 20070627
DESCRIPTION OF SUMMARY: PCM MAY NOT REPROGRAM AND ENGINE SYSTEM ENHANCEMENTS. *KB EXCESSIVE SOOT ACCUMULATION IN EXHAUST. *KB FLASH: ENGINE SYSTEM AND EXHAUST AFTER TREATMENT SYSTEM ENHANCEMENTS. UPDATED 4/28/08. *NJ
NOTE: This bulletin applies to Ram Truck 2500 & 3500 vehicles equipped with 6.7L Cummins turbo-diesel engine (sales code ETJ) built on or before June 11, 2007 (MDH 0611XX).
L
lilfroger
5.9 CTD
TSB 1803507: Transmission defaults to N
Service bulletin #: 1803507
replacement sb#:
Nhtsa item #: 10021999
date: 20070518
make: Dodge
model: Ram
year: 2007
date created: 20070628
description of summary: Transmission defaults to neutral. *kb
L
lilfroger
5.9 CTD
TSB 2100907: 1st-2nd Shift Hunt
Service bulletin #: 2100907
replacement sb#:
Nhtsa item #: 10022003
date: 20070524
failing component: 102000 power train: Automatic transmission
make: Dodge
year: 2004, 2005, 2006, 2007
description of summary: 1-2 shift hunt at light throttle. *kb
L
lilfroger
5.9 CTD
Tsb 1800907: Excesive soot accumulation
Service bulletin #: 1800907
replacement sb#: 1800907b
nhtsa item #: 10022414
date: 20070713
failing component: 063000 engine and engine cooling:exhaust system
make: Dodge
year: 2007
date created: 20070813
description of summary: Excesive soot accumulation in exhaust, pcm may not reprogram, and other engine system enhancements. *kb
Status
