4/6 or 2/4.5 drop
justadodgeman
west virginia
ill be running 26" drag radials and was hoping to get my truck leveled out and not have much of a gap. I will also need some room before it bottoms out cause I plan too hook hard. so right now its either 4/6 with a c-notch or 2/4.5 with tiny bump stops. also does an axle flip cause much wheel hop or anything at the track?
Bullitt5339
St Pauls, NC
26" drag radial? Is that a typo? You can lower it until the frame hits the ground and you're still going to have a big gap.
Can I ask why you are running such a tiny tire on a huge truck?
ST-8
My truck was 4/6 last time I would go to the track I was running a 28" slick an there was quite some gap so good luck with that.
My axel is flipped an running long bars, that solved my hop problems
radikio
