4" BDS with Bilsteins
Discussion in 'Lifted' started by mpittman, Dec 19, 2016.
  1. mpittman
    mpittman Senior Member
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    2015 Big Horn Crew Cab
    Engine:
    I just ordered a 4" BDS lift kit with 3" rear coil springs, and I also have Bilstein 5100 adjustable front struts to level it out. Anyone else running this setup? What did you set your Bilsteins to for a level ride? I don't want much rake. I have nearly a 3" rake as stock.
    The install shop says that BDS has a limit for the front level lift, like 2.5"?? Anyone else hear of that? The shop is an authorized BDS dealer/installer.
  2. Ferro
    Ferro Senior Member
    435
    191
    Sep 17, 2016
    Ram Year:
    Engine:
    I have the zone 4 inch lift which is the same as the BDS and I have my shack set at 1.4 truck sits leve.
    Jershipe likes this.
  3. mpittman
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    Do you have 2" rear spacers or the 3" rear coil springs?
  4. smoothee
    smoothee Senior Member
    747
    210
    Jun 6, 2012
    St. John's, NL
    Ram Year:
    Engine:
    My buddy has the same lift and setup (3" coils) and has his Bils at 2.1.
  5. Ferro
    Ferro Senior Member
    435
    191
    Sep 17, 2016
    Ram Year:
    Engine:
    I have the 3 inch coil springs.
  6. mpittman
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    looks good. 35" tires?
  7. brandonjansen
    brandonjansen Senior Member
    1,689
    899
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    If you have 3" of rake you'll likely want to set the Bilsteins at 1.4". This will remove a total of 2.4" of rake from your truck. It's typically to leave about 0.5" of rake to avoid looking nose high and to allow for a bit of sag when towing/hauling. If you wanted you could set them at 2.1" to remove 3.1" of rake but your truck will likely be sitting nose high with that setup.
    mpittman likes this.
  8. mpittman
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    As always, thanks Brandon.
  9. BogsRam14
    BogsRam14 Senior Member
    452
    180
    Nov 17, 2014
    NJ
    Ram Year:
    Engine:
    Nice choice..... Waiting for pics.
    So Anyone one know what Bils should be set at for Zone 4/2? Maybe @ 0.7 if 1.4 works to level out 3inch coils. I like less wheel gap so doing Zone 4/2 soon with -24offset rims and 35's.
  10. WilliamS
    WilliamS Senior Member
    35
    1,235
    307
    May 3, 2016
    Ram Year:
    Engine:
    wonder if you had the right wheels and tires if 37's will fit on that.
Share This Page
