4" BDS with Bilsteins
Discussion in 'Lifted' started by mpittman, Dec 19, 2016.
  1. mpittman
    mpittman Senior Member
    222
    70
    Aug 5, 2016
    Indiana
    Ram Year:
    2015 Big Horn Crew Cab
    Engine:
    I'm hoping the 35's I have coming won't look too big. I don't want a totally "stuffed" look. I see some 4" jobs and I think WOW that is awesome, then I see another 4" job and i think, that really doesn't even look raised. Could be the size of the tires.
  2. Ferro
    Ferro Senior Member
    435
    192
    Sep 17, 2016
    Ram Year:
    Engine:
    Yes 35's.
  3. brandonjansen
    brandonjansen Senior Member
    1,689
    901
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    It will depend on your stock rake. The Zone kit will remove 2" of rake if you have the 2" coil spacers. So with Bilsteins at 0.7" you'd be removing 0.7" of rake which is likely where you will want them. However every truck is slightly different so you should measure your own to make sure.
    On the right wheels, yes you could. But it would likely require trimming as well.
  4. Medpilot
    Medpilot Junior Member
    27
    21
    Apr 26, 2016
    Gilbert
    Ram Year:
    Engine:
    I have a BDS 4" lift with 3" coil spring in the back with Bills set at 0. Gives me about 1" of rake.
    [​IMG]
    Jershipe and blackbeautyhemi like this.
  5. blackbeautyhemi
    blackbeautyhemi Senior Member
    28
    1,577
    534
    May 19, 2013
    Lewistown, PA
    Ram Year:
    Engine:
    My buddies 4" bds, no bilsteins, 37" trail grapplers
  6. mpittman
    222
    70
    Aug 5, 2016
    Indiana
    Ram Year:
    Engine:
    [​IMG]
    Here's the 4" BDS with 3" rear coils and Bilsteins at 1.4". She sits dead level!
Share This Page
