46re trouble HELP!!!!
Discussion in 'General Discussion' started by badluck, Oct 29, 2016.
  1. badluck
    badluck Junior Member
    Oct 29, 2016
    Ram Year:
    1996 1500 4x4
    Engine:
    5.9 v8
    I have a 1996 ram 4x4 5.9l with 196k Recently the transmission went out of gear and will no longer shift and throws code p1759 for the Governor solenoid. I went ahead and changed both the pressure and Governor Solenoids (BORG WARNER), replaced fresh 6Q of ATF+4 and same issue same code. Also changed the speed sensor same thing???? Any ideas before I waste more fluid and MONEY ... I am broke and need truck for work so any help will be great.. OH and there was no metal pieces or chunks in the pan when I dropped it ...
  2. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,857
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    If the sensor is new and you're still getting that code, more than likely the old was still good. Sounds like clogging in the valvebody
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,405
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Don't take apart the valvebody unless you are absolutely sure you can get it back together.
    If it is in fact a clog, you can do a couple things. Remove the manual lever and pull the manual valve. In order to remove the manual lever you need to unbolt the throttle lever assembly and pull the C clip holding the throttle lever to the manual lever. My memory is a little foggy from when I did it. But that will allow the manual lever to move enough to pull it off.
    Once you have the manual valve removed, you can take an air gun and blow about 10-15PSI into the hole there. Maybe put some ATF+4 in and blow it out some more. Just be careful not to put too much pressure in or you might damage a seal.
    Otherwise, the only way to clean the valvebody is to take it apart, or just run new oil through it until it clears out.
  4. badluck
    Oct 29, 2016
    Ram Year:
    1996 1500 4x4
    Engine:
    5.9 v8
    Done
    Well i took it apart again and found i did not plug the govenor sensor in all the way. This seems to have fixed it then today driving back from work when slowing down and downshifting it started making a loud nasty sound, i pulled over and check the fluid all ok but could smell like burnt oil now reverse is gone . Im no genius but im sure its toast. Thank you all for the help
  5. dudeman2009
    22
    1,405
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    Did it sound like a grinding? I've heard of the parking sprag going bad and sticking, causing this issue and killing reverse.
    Either that or the rear band. If its the rear band, putting it in manual first will cause it to act improperly.
    Or if its the front clutch, then third and fourth gear will have problems.
    Either way, just from what i've read, it sounds like a rebuild.
  6. SportRam00
    SportRam00 Member
    54
    12
    Apr 1, 2016
    Joppa, MD
    Ram Year:
    2000
    Engine:
    Magnum 360
    Great DIY 46re video
    If you want to attempt this rebuild yourself, I found an excellent instructional video on YouTube University.
    https://www.youtube.com/channel/UCXqufnwB1bb0QKnP2Owo3nA
    It's a little boring, but it's broken down into different lessons. The series details the whole breakdown, inspection, and rebuild process.
  7. badluck
    Oct 29, 2016
    Ram Year:
    1996 1500 4x4
    Engine:
    5.9 v8
    Video
    Thank you so much for the Video , I watched the whole thing and have come to realize that it is above my skill set . I found a shop that will drop it,rebuild it and Warranty it for 1200.00 all in unless anyone knows a good shop that cheaper in Phoenix Az,
Share This Page
