4in to 6in zone lift
Discussion in 'Lifted' started by dhows31, Jan 11, 2017.
  1. dhows31
    dhows31 Senior Member
    198
    22
    Mar 25, 2016
    Mississippi
    Ram Year:
    Engine:
    I have a 2012 Ram 1500 with a zone 4in lift and when I get new tires I was just gonna get 37s. So with that being said, does anybody know if this can be done or if it's even worth doing?
  2. brandonjansen
    brandonjansen Senior Member
    1,689
    899
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    It can definitely be done but with all the parts that would need to be swapped to turn a 4" lift kit into a true 6" lift kit you'd be better off full removing your 4" kit and selling it privately and then installing a 6" kit.
    However if you're just looking to get to 6" even then you can stretch your 4" kit up to 6" no problem. Installing a set of Bilstein 5100's on the front end set at 2.1" will bring you up to 6.1" of front end lift.
    What are the wheel specs that you're wanting to run the 37's on?
  3. mpittman
    mpittman Senior Member
    210
    68
    Aug 5, 2016
    Indiana
    Ram Year:
    2015 Big Horn Crew Cab
    Engine:
    I used Bilsteins on my 4" BDS kit. My front end actually rose 6.75" from the stock height. But that also includes the 35" bigger tires.
    Could a 1" rear spacer also be added to the rear with a 4" lift kit?
  4. dhows31
    198
    22
    Mar 25, 2016
    Mississippi
    Ram Year:
    Engine:
    The only parts that are different though are the spacers on the coil springs and a few other parts though right? I think most of it is the same. And I currently have stock wheels but I'm trying to get 20x10 with maybe a -something offset. I do already have the bils though.
  5. Jershipe
    Jershipe Senior Member
    41
    259
    74
    Nov 5, 2016
    Monroe Michigan
    Ram Year:
    Engine:
    I have the rcx 4 inch kit. I put bilstiens at 1.4 up front and added 1 1/2 spacer in rear. The front is lifted 5.5 and the rear 4. Only extra parts I had to get was a rear track bar bracket. Because the rcx 4 inch kit doesn't relocate it. Only run 35's on stock 20x9's. But 37's would fit no problem.
  6. Ferro
    Ferro Senior Member
    435
    191
    Sep 17, 2016
    Ram Year:
    Engine:
    Don't you need a 6 inch spindle as well.
  7. Jershipe
    41
    259
    74
    Nov 5, 2016
    Monroe Michigan
    Ram Year:
    Engine:
    Don't think you have too. It's just like running a level on a non lifted truck. As long as your cv angles are ok. Should be fine.
  8. dhows31
    198
    22
    Mar 25, 2016
    Mississippi
    Ram Year:
    Engine:
    Yeah I think I remember talking to Zone about it. I might should give them a call. Im pretty sure it's just a few different parts but like everyone said that I should go ahead and get the 6in. Congrats guys you were right :)
  9. fordtech90
    fordtech90 Senior Member
    414
    99
    Sep 27, 2015
    Jonesboro, La 71251
    Ram Year:
    Engine:
    So a 6" lift and bils set at 2.1 will give you roughly 8.1" over stock?
  10. brandonjansen
    1,689
    899
    Feb 14, 2013
    Ram Year:
    Engine:
    Provided your rear end lift was done with the 3" coils then yes, you can add a 1" spacer on top of them if more lift is desired.
    It should be the majority of the lift kit. Crossmember drop brackets, diff drop brackets, steering knuckles, strut spacers, rear springs, rear track bar drop bracket... this is assuming a true 4" lift VS a true 6" lift. I'm not sure what, if any, parts that Zone crosses over between their kits. I could talk to my rep at Zone and look into this for you if you'd like.
    No. Although it does seem like that should be the case, that's not how it works. Most 6" kits actually provide 5.5" of lift out of the box. So already we lost a 1/2". On a Zone kit (and others) 5/8" of that lift is from a preload spacer that's installed on the OEM strut. When you use Bilsteins you don't install the preload spacers as the Bilsteins provide the preload for you. So now we're down to 4 7/8" from the strut spacer plus whatever the Bilsteins are set at. So in the case of 2.1" you end up with a total front end lift height of ~ 7.0"
Share This Page
