4th Gen seats in a 3rd Gen
HemiSport07
Central FL
I know it has been done I'm curious if anyone on the forum has done it I'm looking at a set of heated and cooled seats wondering how I could get all that to hook up in my truck I already have the heated seats. Also curious I see these seats have airbags wondering if that would be an issue? Thanks
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
As long as the wiring and the connectors are the same thee should be no issues. I would track down the air bag wiring though if the connectors are different, and completely remove them for safety. They will go off if not handled properly.
BigSloth
Mobile, AL
2014 1500 CCSB Black Express
Yeah there are no side curtain airbags in 3rd gens, so there is nothing to wire to with the new ones.
But, I dont think there are airbags in the seats themselves. I believe they are in the B pillars along the roofline under the headliner and behind the pillar. I think they just put the SRS airbag insignia on the seats so you see it as you're getting in. But I'm not positive of that, thats just the way most every manufacturer does it.
BigSloth
Mobile, AL
Unless they added side curtains in 07 that is.
Either way, if you are going to do anything to an airbag system, disconnect the battery and wait 3 minutes. You dont want to set any DTC's in the airbag system or the light will come on and stay on until someone with an SRS capable scantool resets it.
MegaMouseGW
South Louisianna
I think the first year they offered side airbags was 2008 or 09 but not sure on that, and only in the best trim levels.
HemiSport07
HemiSport07
Central FL
Yea if that's the case maybe I can have an upholstery shop take the covers off and disable them I'm just confused on the ventalated seats I would probably have to run wires to them I just know how sensitive the computer systems are on the 07 and up and that makes me hate wiring things on my truck. Does anyone know is there any market for the sport leather seats in my 07?
Dekman
Cummins 5.9
The Wiring is completely different , power is easy but the heating and cooling go through a module. If you figure them out please post it Im in the same dilema.
moparman
Woonsocket, RI
2016 Ram 2500
I'm somewhat in the same boat as you with my 05. I picked up a set of heated/power leathers out of an 02 at the junkyard. my truck being a base model has nothing for it to be plug and play. the heated seat module is built into the bottom of the seat and when I removed the seats from the organ donor, I snipped the harness under the seat so I had a pigtail with the connector and I also removed both seat heat switches with pigtailed harnesses as well. I went on all data and got a pin out of that plug, heat switches and a schematic of the heated seat module itself. power seats themselves are power and ground, all the heated seat switches are wired directly to the module itself so it was a process of reconnecting the two together. I'm not sure on the 4th gen seats but if its the same as the 3rd gens, it wont be too bad of an install to reconnect everything. The seat belt light on the cluster is tied into the drivers buckle attached to the seat so you'll need to make sure you either transfer the buckle and remove the harness from the old seat or connect the buckle from the new seat to your existing seat harness on the floor. if the seats you're putting in have air bags in them, there's no need to spend the time or money to have them removed. I disable steering wheel air bags all the time for the handicap with a system approved by NHTSA and I've yet to have an issue. being disconnected there's no way for them to deploy since they're self shunting. The swap is doable, you just need to take the time to figure it all out and make it work. my 05 has CanBus like your 07 and I've had no issues with the seats being in. its basically just power and grounds
HemiSport07
HemiSport07
Central FL
Thanks for all the info I'm gonna bite the bullet and order them Friday ill post up pictures of the install which my take a while cause I work out of state
moparman
Woonsocket, RI
2016 Ram 2500
No problem, i can get you the wiring diagrams if you need them
Sent from my Galaxy S3 using Tapatalk 2
camdlstire
2011 Seat Swap
So I have swapped my 2011 seats for 2015 in my Quad Cab and my seat belt light is on and same as my airbag light... Now I have taken my old seatbelt and plugged it into the new seats but that didn't do anything. However, the only wires I have hooked up right now are the power and ground. Are there other wires I need to wire together? If so, which ones to get the lights to go off?
drod327
San Antonio TX
2022 Ram 1500
I just started a thread for the exact same reason. I put leather 4 gens in my 07 ram. Did you find a fix for this? I have a seat belt light and air bag light on.
Berubixcube
Able to send a schematic to me please, i have gotten cool to work, seat belt light off, just need to figure out which wire is heat and what to do to get airbag light off.. thanks in adavance.
therapywolf
