4th Gen Technical Service Bulletins
Discussion in 'Tech Info' started by lilfroger, Nov 8, 2010.
Thread Status:
Not open for further replies.
  1. lilfroger
    lilfroger Senior Member
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. TSB's are registered with the US Government and below is an export of that data.
    To search for TSB's for your specific Year / Model please see: ODI - Office of Defects Investigation
    The included information does not have step by step "how-to" or part numbers. It is simply a notification that there was a problem with a specific component.
    TSB's are performed by Dodge dealerships for no cost if the component is still covered under warranty. For the most part if your vehicle is outside the bumper-to-bumper warranty the service will be billable. Some individual components have an extended service warranty due to a specific failure. Speak with your local Dodge service representative to check the status of your vehicle.
    The "SERVICE BULLETIN #" or "REPLACEMENT SB#" numbers provided are provided by Dodge and should be searchable by your Dodge service representative.
  2. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb csn-k17: Hvac mode door actuator gears
    Service bulletin #: Csn-k17
    replacement sb#:
    Nhtsa item #: 10034072
    date: 20100901
    failing component: 118000 electrical system: Software
    make: Dodge
    model: 1500, 2500, 3500
    year: 2009, 2010
    date created: 20101015
    description of summary: Dodge: Reprogram hvac control head and inspect/replace actuators. The hvac mode door actuator gears on vehicles may break and result in the inability to fully control the hvac functions. Csc letter was rec'd. *pe
  3. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb csn-k20: Engine water pump leak
    Service bulletin #: Csn-k20
    replacement sb#:
    Nhtsa item #: 10034071
    date: 20100901
    failing component: 062000 engine and engine cooling:cooling system
    make: Dodge
    model: Ram
    year: 2010
    description of summary: Ram/dodge/jeep: The engine water pump on certain vehicles may leak coolant. Engine operation with a low coolant level could cause engine damage or low cabin heater output. Csc letter was rec'd. *pe
  4. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb sb-19-004-10: Steering wander
    Service bulletin #: Sb-19-004-10
    replacement sb#:
    Nhtsa item #: 10033731
    date: 20100529
    failing component: 014100 steering:rack and pinion:pinion shaft
    make: Dodge
    model: 1500, 2500
    year: 2009
    date created: 20100915
    description of summary: Dodge: Steering wander. While traveling on a straight stretch of highway, customer may feel the need to provide steering input to correct a vehicle wander condition. *pe
  5. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb sb-18-003-10: Short runner valve
    Service bulletin #: Sb-18-003-10
    replacement sb#:
    Nhtsa item #: 10033690
    date: 20100115
    failing component: 114000 electrical system:wiring
    make: Dodge
    year: 2009
    date created: 20100910
    description of summary: Dodge: Bulletin involves replacing the short runner valve (srv), srv connector, wiring pigtail, and adding a new stud for a tie strap. *pe
  6. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb sb-19-002-10: Steering wander
    Service bulletin #: Sb-19-002-10
    replacement sb#:
    Nhtsa item #: 10033671
    date: 20100123
    failing component: 010000 steering
    make: Dodge
    model: 4500, 5500
    year: 2009
    date created: 20100903
    description of summary: Dodge: Steering wander. Involves selecting the proper repair procedure based upon vehicle build dates and then aligning the vehicle with revised specs. *pe
  7. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb sb-14-001-10: Ctd electronic fuel control actuator
    Service bulletin #: Sb-14-001-10
    replacement sb#:
    Nhtsa item #: 10033546
    date: 20100202
    failing component: 061200 engine and engine cooling:engine:diesel
    092100 fuel system, other:delivery:fuel pump
    make: Dodge
    model: Ram
    year: 2009
    date created: 20100823
    description of summary: DODGE: ELECTRONIC FUEL CONTROL ACTUATOR (FCA) AVAILABLE FOR SERVICE/NEW DIAGNOSTICS AVAILABLE FOR DTC P0251. ENGINE SURGES AT IDLE OR MIL ILLUMINATION. FURTHER INVESTIGATION MAY IDENTIFY DTC P0251-CP3 PUMP REGULATOR CONTROL-DIESEL. IF P0251 IS PRESENT, FOLLOW THE DIAGNOSTICS IN THIS SB. IF OTHER DTC'S ARE PRESENT, REPAIR AS NECESSARY BEFORE PROCEEDING FURTHER. MODEL RAM TRUCK. *PE
  8. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb sb-09-050: Improved fuel tank venting
    Service bulletin #: Sb-09-050
    replacement sb#:
    Nhtsa item #: 10033185
    date: 20090825
    failing component: 071100 fuel system, gasoline:storage:tank assembly
    make: Dodge
    model: 3500, 4500, 5500
    year: 2009
    date created: 20100723
    description of summary: Dodge: Improved fuel tank venting. Vehicles were shipped with a fuel tank vent that under severe conditions, may allow moisture and debris to enter the fuel tank through the vent. Dealers are requested to replace the fuel tank vent with a revised part. *pe
  9. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb dr-j-35: Ctd heavy sooting
    Service bulletin #: Dr-j-35
    replacement sb#:
    Nhtsa item #: 10033113
    date: 20100401
    failing component: 063130 engine and engine cooling:exhaust system:emission control:gas recirculation valve (egr valve)
    061000 engine and engine cooling:engine
    make: Dodge
    model: 2500, 3500
    year: 2009
    date created: 20100708
    description of summary: DODGE: ENGINE CONTROL MODULE (ECM) SOFTWARE PROGRAM ON ABOUT 159,700 TRUCKS MAY CAUSE ILLUMINATION OF THE MALFUNCTION INDICATOR LAMP (MIL) WHEN NO PROBLEM EXISTS OR UNDER CERTAIN CONDITIONS ALLOW HEAVY SOOTING OF THE TURBOCHARGER, EXHAUST GAS RECIRCULATION VALVE AND DIESEL PARTICULATE FILTER. HEAVY SOOTING COULD DAMAGE EMISSIONS COMPONENTS AND RESULT IN INCREASED EMISSIONS. THE ENGINE CONTROL MODULE MUST BE REPROGRAMMED (FLASHED). CSC LETTER WAS REC'D. *PE
  10. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB ER-J-22: Rear Axle Ratio
    Service bulletin #: Er-j-22
    replacement sb#:
    Nhtsa item #: 10033107
    date: 20100301
    failing component: 106000 power train:axle assembly
    make: Dodge
    model: 2500
    year: 2009
    description of summary: Dodge: The axle(s) on about 160 certain ram truck vehicles were inadvertently built with a 4.10 axle ratio. This is a non compliant powertrain configuration and could impact the vehicle's fuel economy and/or performance. The axle ring and pinion(s) must be replaced with 3.73 axle ratio ring and pinion(s). The tipm must also be reprogrammed for the new axle ratio. Csc letter was received. *pe
Thread Status:
Share This Page
