Hi Mate! First of let me introduce myself a bit by saying how much i love those LA based mopar engines especially the new type known as Magnums, The new heads design is much better then before and the efi is really simple to play with. Love these motors so much i bought a 07 Magnum sxt for family purposes with the v6, already planned to swap a 318 into it, btw its already in there and running, now just started the turbo setup phase.
Lots of folks argued that i should've bought an R/T instead but the price difference for 100 more hp ain't worth it IMO, plus having to own a Chrysler scan tool to heck tranny fluid level ect is ridiculous to me, I love the simple stuff. I did ''Back then'' turbo'ed 2 of my previous ram trucks.
Had the same initial dillema, SC or turbo!?! Like u, i tough SC was a better option for this engine, i was wrong! First I gotta mention that i've always upgraded my boosted engines with forged pistons, cost about 500ish$, Rods and crank will take it no problem ''Never planned to make over 500-550hp'' plus ARP head studs and stronger heads gaskets, & if u plan on making good hp #s i recommend to install the plennum fix kit from Hughes engines since ours are famous to crack.
Started first by custom fit a Centrifugal unit '' Powerdyne'' I had laying around. Not the most technological advanced unit on the market compared to new vortechs or prochargers but tried it still. Near 9 psi the belt start slipping like most centrifugals plus needs lots of rpms to provide the ''wanted''boost. In other words unless u don't mind seeing good hp #s only near cutoff then its not worth it IMO. Some centrifugal kits out there will perform better but be prepared to spend ridiculous amount of money on it.
Then wanted to try a eaton root style setup, a friend of mine sold me a good condition m112 for cheap so i went for it! ''BTW a m90 isnt big enough for a 5.2, rated for 3.0-4.0 engines only'' . Those blowers produces lots of heat so if u expect it to push 9-10 psi + you'll need an Intercooler/aftercooler setup,to be efficient, those blowers need to be as close as possible to the IM, Since i didn't want to craft my own water cooled IM as the actual IM I've mounted it on the side of the engine bay so i have room for Piping/tb setup '' u'll have to relocate the TB @ the Blower inlet'', with all that done results werent that great. about the same gains hp wise compared to the centrifugal exept i had way more low end tq/hp. Not worth all the custom fab. i'm sure the blower would've made bigger #s top mounted but i didnt feel like building a custom water cooled IM lol.
Then finally i went Turbo, Took the time to mock up the setup and ended up choosing Single turbo. What i did was to invert both exhaust manifolds ''minor fab required'' so they both faced the front, merged them with a u style pipe then welded a y style pipe to the turbo flange, mounted on the front. Then intercooler setup, Bigger inj. high flow fuel pump with a turbo grind cam with low LSA and Hughes engines Big Gulp TB with a Holset HX40 turbo @ 13 psi it made 455whp, Kept it on the safe side and didnt went higher boost.
