220 might be a little high, if consistent under a light load. When my truck was in it's first 5000 miles or so and completely unaltered, my high way oil temps were in the 211 to 214 range. They did climb to 220-ish under hard acceleration. Coolant was around 206 and the transmission was around 188. Now that I've removed the shutter assembly and replaced the 203 degree T-stat with a 180 degree unit, my oil temps in the summer hovered between 199 and 204. After I added Lubegard at my last oil change, my oil temps have come down a bit more. Not pulling my enclosed cargo trailer, on the highway I have to work the truck to exceed 192 oil temp; pulling the trailer, oil temps sit near 199 and will crack 200 if I accelerate hard or fight a strong headwind. Running 0w-40 oil too, so Lubegard clearly is reducing some friction.
