5.9 diesel 3500 / 2006
Discussion in 'Engine and Performance' started by purplhrt91, Nov 19, 2014.
Sponsored By: Moe's Performance
  1. purplhrt91
    purplhrt91 Junior Member
    8
    Nov 19, 2014
    Ram Year:
    2006
    Engine:
    5.9
    Is there a way to make the Turbo whistle louder? Take a ring out or something like that?
    What is the best CAI to get for it and will this help with fuel economy. Haven't had a diesel for awhile so just getting back to it and would like to get a little more power out of her without spending a fortune. All advice and input appreciated. Thanks
  2. Power247
    Power247 Senior Member
    42
    5,502
    809
    Jul 26, 2012
    High Point, NC
    Ram Year:
    Engine:
    CTD 6.7
    What kind of mileage are you getting now?? Do you have any mods on the truck now? running any tuning?
  3. purplhrt91
    8
    Nov 19, 2014
    Ram Year:
    2006
    Engine:
    5.9
    No MODs. Getting any where from 12-15 mpg
  4. Stangshcky12
    Stangshcky12 Super Moderator Staff Member
    9,057
    888
    Oct 26, 2011
    Oshkosh, WI
    Ram Year:
    Engine:
    5.9 Cummins
    There's a silencer ring in the turbo, take off the intake elbow and remove the snap ring with a flat head screw driver and you can pull the ring out
    The stock intake has baffles in the torque tube
    Any intakes really going to do the same thing
    S&B are popular
    I like my AFE with a dry filter, didn't notice any difference in power, didn't have the truck stock long to know if it did anything for mileage
  5. purplhrt91
    8
    Nov 19, 2014
    Ram Year:
    2006
    Engine:
    5.9
    I appreciate the info, but I am back to being a novice at this, sorry but what is the torque tube and should I even mess with it?
  6. Stangshcky12
    9,057
    888
    Oct 26, 2011
    Oshkosh, WI
    Ram Year:
    Engine:
    5.9 Cummins
    The "torque tube" is in the stock intake
    The stock intake consists of the airbox and filter, a 90* elbow, the "torque tube" that is a large baffle and another 90* elbow
    Most intakes will replace all of that and increase intake noise
    While it's louder in the cab it's not really louder outside of the vehicle, You'll never get the whistle that you hear from a powerstroke out of these trucks
  7. purplhrt91
    8
    Nov 19, 2014
    Ram Year:
    2006
    Engine:
    5.9
    Thank you for for all the info and help, I appreciate the quick reply.
    JP
  8. Cummins Powered
    Cummins Powered Senior Member
    132
    24
    Sep 8, 2014
    Ram Year:
    2008 Ram 2500 4x4 3.73 gears,1994 Ram 2500 4x4 12 valve modified, Industrial Injection #5 fuel plate
    Engine:
    6.7 Cummins, 5.9 Cummins
    Like they mentioned above a good cold air intake replacement. Banks Power makes a good enclosed air intake, has a good loud intake sound very large filter housing, will make an increase in the whistle sound for the turbo. Banks also provides a super scoop which works like a ram air effect, forcing more air to the turbo increasing turbo whistle. An intake manifold also helps and provides air flow while increasing the turbo for faster spool up, and more turbo whistle. Banks Power has a set up for your 5.9, Monster Ram intake manifold. You can also remove the stock turbo compressor wheel and replace with a wicked wheel. If you install all items mentioned, with 5 inch turbo back exhaust will really spool your turbo, with the sound you want. If thats not loud enough, you'll need a bigger turbo. The more air-flow the better, but with that type of air-flow, works even better with a tuner, module, or down-loader for the proper amount of fuel being burnt.
  9. purplhrt91
    8
    Nov 19, 2014
    Ram Year:
    2006
    Engine:
    5.9
    Sounds good to me. Thanks.
  10. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    My 05 is almost ear piercing take the silencer ring out and run your air filter with no enclosure at all. That's what I did and you may consider quitting it back down.
    05 Ram 5.9 Cummins Sundown Audio Old School PPI
Share This Page
