5.9 magnum swap in 88 w100
1988ram
Hi I have a 1988 w100 5.2 magnum 4 barrel 4 speed manual transmission truck and the 5.2 is wore completely out smokes bad and no power and I have a 98 5.9 magnum with 60k on it I know I have to use the magnum flywheel but what clutch to use is the problem mine is 23 spline and magnum is 10 spline will the 88 pressure plate fit the magnum flywheel sorry for the paragraph new to the forum
Sniper X
First off, the 5.2 Magnum was a swap too sine the magnum didn't come in these trucks till 1993.
1988ram
Sorry for the slow response haven't had time from work to reply but I put the 5.2 magnum in it when I first got the truck it is out of a 98 Ram 1500 and had high miles when I put it in
