catch_kc
- Apr 13, 2018
- 16
- 1
- Location
- Las Vegas, NV
- 2001
- 5.9 Magnum
Hello all, first time post on this forum, so thank you for having me.
Well, as the title says, I have multiple misfire codes on my 2001 5.9 magnum that I just bought. The code scanner reads P0300, P0301, P0302, P0303, P0304, and P0305.
I bought this truck for cheap with 160k miles and the seller told me the head gasket was blown... however, no coolant in the oil and vice versa. Also, no smoke or condensation from the exhaust. The truck does run and idles pretty smooth, but revs and drives rough. It doesnt overheat either or seem to consume coolant (ran it at idle for about 30-40 mins while searching for vacuum leaks and temps stayed aroind 215-ish.).
I pulled the spark plugs and they all looked like it's running rich.... except cylinder 3... that plug was melted. So I replaced all plugs (with Champion Copper plugs) and verified plug wires were going to the correct cylinders from the distrubuter.
I then restarted and still had the misfire codes minus the P0305. So now I only have the front 4 cylinders misfiring (1-4)... I'm kind of at a loss.
I have searched for this issue on this forum and havent found anything thats similar to this. I've also read through the plenum posts... but I'm not sure if this applies or not.
So any input is greatly appreciated. I love the truck, I just want to enjoy it. I'll be testing the compression tomorrow, so I'll post those results.
Thanks for your help in advance.
