5.9 starting help
Discussion in 'Tech Info' started by B1gch1n0, Nov 27, 2016.
  1. B1gch1n0
    B1gch1n0 Junior Member
    Nov 27, 2016
    Ram Year:
    98
    Engine:
    5.9
    I just bought I 98 5.9 cummins turbo diesel truck. When you walk out to the truck first thing in the morning or after sitting for a while. I put the key in give it some time for flow plugs to warm up and then it fires right up really quick! Cool no problems! Now if I drive to the store turn it off shop for idk 20 min come out it takes a while of cranking to turn over. Some times does not want to run at all!? What could be the problem what do I need to do? Any help would be great thanks
  2. dapepper9
    dapepper9 Senior Member
    22
    4,831
    1,865
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Cummins don't have glow plugs. Instead they use a grid heater but it works to do a similar function but from outside the cylinder.
    Have you tried following the same procedure yout do in the mornings?
  3. B1gch1n0
    Nov 27, 2016
    Ram Year:
    98
    Engine:
    5.9
    Yes I have. I do the same procedure always. And thank you for letting me know about the grid heater. Do I still need to let warm up like glow plugs?
  4. dudeman2009
    dudeman2009 Senior Member
    22
    1,454
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Both 12v and 24v Cummins will do this when the injection pump starts going bad. Moreso on the 24v with the VP-44 pumps. Keep a bottle of cold water on hand, when it has a hard start, drench the injection pump and try it again. If it starts up fine, then thats likely the culprit.
    Is there a lot of smoke on startup?
  5. B1gch1n0
    Nov 27, 2016
    Ram Year:
    98
    Engine:
    5.9
    No I can't remember seeing smoke when it starts. But thank you for the info.
Share This Page
