5 speed automatic trans question
tdekubber
I hate my 5 speed automatic trans, shifts into overdrive to early, shifts to 4th with slightest movement of pedal. Any programmer fixes to this?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
SuperChips 3865 with the Advanced Tranny Tuning. :D
shadow11
Banned
Houston TX
Like Jeremy said, get the Superchips 3865 and you won't regret it!
bigtigga84
dela....where?
Or if you have a droid wait till vivid comes out. Has there been any more word on that?
Sent from my DROID2 GLOBAL using Tapatalk
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
the superchips along with a set of 4.56 gears in the rear helped my tranny out tremendously. with the tuner you can set the shift points anywhere you want. the gears really helped with it shifting at stupid times, and searching around for gears so much.
RAMpage
Kentucky
custom 5.7/6.1 hemi hybrid
you should just drive faster lol then it wont have a need to shift back into forth lol. na i have the same problem so im in the process of huntin some gears for me truck but im not payin 950 for some gears without a lsd in the package too.
glass3222
Central PA
Like others said sc does it very well. I will also add that diablo does a good job with trans tuning as well.
mmcquinn
