545rfe issues
Moneypit2006
Hi was wondering if anyone out there has experianced any issues like mine. I replaced the trans about six months ago everything was fine until about a month ago i go to leave work and my trans is slipping keep in mind it had been fine for 5 months. I limp it home thinking great need to replace trans again. Well i pulled codes and it was p0700 and all the p0730 somthings to do with wrong gear ratio. I cleared codes let it sit couple hours then it worked fine again so since the fluid looked and smelled a little burned i changed filters and fluid. All was fine again till a month later then happens again this time its not coming out of it. So i realy dont know what to do now i can get a trans from a 2007 just not shure if the electronics will work with my 06 any input would be great. Thanks
M
Moneypit2006
Thanks for the info i will look a little deeper before i tear the trans out. Also if anyone knows if that 2007 trans would work in my 06 that would be good to know i can get it at a good price.
M
Moneypit2006
My truck is a 2006 anyone had any luck swapping in trans from different years can get a 2004 trans for decent price
SilverStreak88
Houston, Texas
5.7 Eco Gasser
They should swap without issue, the only concern I would have is with the PCM controlling it. I don't know if the 06 will have communication issues with the 04.
M
Moneypit2006
Thats kinda what im worried about if anyone has done this let me know i was thinking a quick learn aftet install might make it work
lharrell79
06 is Can Bus, and 04 is not. It might not work.
M
Moneypit2006
Just letting anyone out there know i just installed the 04 trans out of 1500 and put it in my 06 2500 changed the transfer case adaptor from old trans to new one. That was only differance it seems to shift abd drive as it should havent had a quick learn done yet but running and driving
HemiLonestar
MD
For the most part the RFE's are interchangeable back and forth, I think there was a change to the connector on the solenoid pack but I can't remember what year that was. To the OP, when you replaced the trans, did you do it or a shop? Was a quick learn performed afterwards before driving it around?
