6.4 MPG with level and 35s
King nothing
Central IL
Cummins
What kind of MPGs are you guys with a level and 35 inch ATs getting. I’m looking at 2 inch Thuren springs in the front and 1 inch rear and 285/75r18 (35x11) all terrains. She’s already thirsty, so I’m hoping it’s not too significant of a drop. Would a 35-12.50 be significantly worse than the 285? 3.73 gears
Rampant
NJ
392 Hemi
I have 35x12.5x20's but not leveled. '16 CC Laramie 6.4/3.73 gears. I avg 13-14 mpg per tank, hand calc, running 89 octane.
SHOOT2KILL
2015...2500H.D.
MPG on mine with mudders are down atleast 2-3mpg from Nov thru March...Some of that loss can be attributed to winter blend fuel also...The tires are 275-70-18 (33.5")...10 ply...They weigh 60# ea...My truck is leveled in the front with Timbrens...
K
King nothing
Central IL
Cummins
You lost 2-3 mpg with stock size mud tires?
K
King nothing
Central IL
Cummins
Do you think the 89 octane helps with your mileage? I’ve been running 87
Rampant
NJ
392 Hemi
To be honest, I don't know. I always run 89, other than the few times I tried 93 while towing. I couldn't tell any difference in performance or mileage, so I just stick with 89.
Sent from my SM-G950U using Tapatalk
6.4LMegaMan
6.4L
I'm running a 2" level on 295/65R20 Toyo AT2 which is a 35" tire on a 2016 2500 mega cab with 6.4L and 3.73 gears. I get hand calculated average of about 11 city / 15 highway. And that is on 50 psi front / 45 psi rear and I corrected the speedometer using an AEV ProCal. I also use a pedal commander which I would assume the mpgs take a small hit from that too.
Sent from my SAMSUNG-SM-N920A using Tapatalk
K
King nothing
Central IL
Cummins
I think that’s better mileage than I get with the stock size tires lol
6.4LMegaMan
6.4L
Ha. When I was stock I was getting 13/17. Our highways here keep the speed low though. That's the key. I never get above 65 really. 55 is the sweet spot it seems for me.
theviking
I'd happily pay the gas bill over having to drive 55 everywhere.
K
King nothing
Central IL
Cummins
My wife would crap a brick if I set the cruise at 65 on the interstate. I have been running right at 70 which is the speed limit here and running 60 on the 55mph 2 lanes. Don’t think im getting much better than 12.5 average
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
55 mph is the sweet spot for my 37x12.50s as well. Evic gets up to 13.0 - 13.6 at 55.
I usually chug along at 60 - 65 and the evic stays around 12.0 - 12.4.
When I'm "in a hurry" and cruise around at 70 it drops to 11.4.
hand calc is usually about 1.2 mpg lower than evic.
ocwill1
Severn, MD
5.7 eTorque
2 inch thuren, 35x12.5x18 Toyo AT's and I get 11-12 mixed, mostly consider what I do city driving... My commute to work is only 16 miles each way, about 10 of it on highway.....
I got right around 16 on vacay to north carolina this spring, when not in traffic...
