lilfroger
- Aug 29, 2010
- 1,224
- 7
- 2006
- 5.9 CTD
P000f-fuel System Over Pressure Relief Valve Activated
P0016-crankshaft/camshaft Timing Misalignment - Bank 1 Sensor 1
P0031-o2 Sensor 1/1 Heater Circuit Low
P0037-o2 Sensor 1/2 Heater Circuit Low
P003a-turbocharger Boost Control Module Position Exceeded Learning Limit
P0046-turbocharger Boost Control Circuit Performance
P0049-turbocharger Turbine Overspeed
P006e-turbocharger Boost Control Module Supply Voltage Circuit Low
P006f-turbocharger Boost Control Supply Voltage Circuit High
P0071-inlet Air Temp Sensor Rationality - Ecm
P0071-ambient Air Temperature Sensor Performance (tipm)
P0072-inlet Air Temp Sensor Voltage Too Low - Ecm
P0072-ambient Air Temperature Sensor Circuit Low (tipm)
P0073-inlet Air Temp Sensor Voltage Too High - Ecm
P0073-ambient Air Temperature Sensor Circuit High (tipm)
P007c-charge Air Cooler Temperature Sensor Circuit Low
P007d-charge Air Cooler Temperature Sensor Circuit High
P007e-charge Air Cooler Temperature Sensor Circuit Intermittent/erratic
P0087-fuel Rail Pressure Too Low
P0088-fuel Rail Pressure Too High
P00af-turbocharger Boost Control Module Performance
P0101-mass Air Flow Sensor "a" Circuit Performance
P0102-mass Air Flow Sensor "a" Circuit Low
P0103-mass Air Flow Sensor "a" Circuit High
P0106-manifold Absolute Pressure Sensor Performance
P0107-manifold Absolute Pressure Sensor Circuit Low
P0108-manifold Absolute Pressure Sensor Circuit High
P0111-intake Air Temperature Sensor 1 Performance
P0112-intake Air Temperature Sensor Circuit Low
P0113-intake Air Temperature Sensor 1 Circuit High
P0116-engine Coolant Temperature Sensor Performance
P0117-engine Coolant Temperature Sensor Circuit Low
P0118-engine Coolant Temperature Sensor Circuit High
P0128-thermostat Rationality
P0131-o2 Sensor 1/1 Circuit Low
P0135-o2 Sensor 1/1 Heater Performance
P0137-o2 Sensor 1/2 Circuit Low
P0141-o2 Sensor 1/2 Heater Performance
P0148-fuel Delivery Error
P0169-water In Fuel Detected For Too Long
P0191-fuel Rail Pressure Sensor Circuit Performance
P0192-fuel Pressure Sensor Low
P0193-fuel Pressure Sensor High
P0201-fuel Injector 1 Circuit/open
P0202-fuel Injector 2 Circuit/open
P0203-fuel Injector 3 Circuit/open
P0204-fuel Injector 4 Circuit/open
P0205-fuel Injector 5 Circuit/open
P0206-fuel Injector 6 Circuit/open
P0217-coolant Temperature Too High
P0219-engine Overspeed
P0251-injection Pump Fuel Valve Feedback
P0300-multiple Cylinder Misfire
P0301-cylinder 1 Misfire
P0302-cylinder 2 Misfire
P0303-cylinder 3 Misfire
P0304-cylinder 4 Misfire
P0305-cylinder 5 Misfire
P0306-cylinder 6 Misfire
P0335-crankshaft Position Sensor Circuit
P0336-crankshaft Position Sensor Performance
P0340-camshaft Position Sensor Circuit - Bank 1 Sensor 1
P0341-camshaft Position Sensor Performance - Bank 1 Sensor 1
P0381-wait To Start Lamp Inoperative
P0400-egr System Flow Malfunction
P0401-egr System Performance
P0402-egr Flow Excessive Detected
P0403-egr Control Circuit/open
P0404-egr Position Sensor Performance Diesel
P0405-egr Position Sensor Circuit Low
P040b-exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
P040c-exhaust Gas Recirculation Temperature Sensor 1 Circuit Low
P040d-exhaust Gas Recirculation Temperature Sensor 1 Circuit High
P0420-catalyst Efficiency Bank 1
P042e-exhaust Gas Recirculation Control Stuck Open
P0461-fuel Level Sensor 1 Performance
P0462-fuel Level Sensor 1 Circuit Low
P0463-fuel Level Sensor 1 Circuit High
P0471- Exhaust Pressure Sensor 1 Performance
P0472- Exhaust Pressure Sensor 1 Low
P0473- Exhaust Pressure Sensor 1 High
P0480-cooling Fan 1 Control Circuit/open
P0483-cooling Fan Speed
P0487-egr Airflow Throttle Control Circuit A Open
P0488-egr Airflow Throttle Control Circuit Performance
P0489-egr Control Circuit Low
P0501-vehicle Speed Sensor 1 Performance
P0505-engine Speed At Idle - Data Erratic, Intermittent Or Incorrect
P0513-invalid Skim Key
P0514-battery Temperature Sensor Performance
P0516-battery Temperature Sensor Circuit Low
P0517-battery Temperature Sensor Circuit High
P051b-crankcase Pressure Sensor Circuit Range/performance
P051c-crankcase Pressure Sensor Circuit Low
P051d-crankcase Pressure Sensor Circuit High
P0521-engine Oil Pressure Sensor Performance
P0524-engine Oil Pressure Too Low
P0532-a/c Pressure Sensor Circuit Low
P0533-a/c Pressure Sensor Circuit High
P0541-intake Air Heater Control Circuit 1 Low
P0542-intake Air Heater Control Circuit 1 High
P0545-exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546-exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P0562-battery Voltage Low
P0563-battery Voltage High
P0571-brake Switch 1 Performance
P0572-brake Switch 1 Stuck On
P0573-brake Switch 1 Stuck Off
P0580-speed Control Switch 1 Circuit Low
P0581-speed Control Switch 1 Circuit High
P0585-speed Control Switch 1/2 Correlation
P0592-speed Control Switch 2 Circuit Low
P0593-speed Control Switch 2 Circuit High
P0601-internal Memory Checksum Invalid
P0604-internal Control Module Ram
P0606-internal Control Processor
P0607 Ecu Internal Performance
P061a-etc Level 2 Torque Performance
P061c-etc Level 2 Rpm Performance
P0622-generator Field Control Circuit/open
P0628-fuel Pump Control Circuit Low
P0629-fuel Pump Control Circuit High
P062c-etc Level 2 Mph Performance
P0630-vin Not Programmed In Pcm
P0633-skim Secret Key Not Stored In Pcm
P063c-generator Voltage Sense Low
P063d-generator Voltage Sense High
P0642-sensor Reference Voltage 1 Circuit Low
P0643-sensor Reference Voltage 1 Circuit High
P0646-a/c Control Circuit Low
P0647-a/c Control Circuit High
P0652-sensor Reference Voltage 2 Low
P0653-sensor Reference Voltage 2 High
P065a-generator System Performance
P0698-sensor Reference Voltage 3 Circuit Low
P0699-sensor Reference Voltage 3 Circuit High
P06a4-sensor Reference Voltage 4 Circuit Low
P06a5-sensor Reference Voltage 4 Circuit High
P0700-transmission Control System (mil Request)
P0850-park/neutral Switch Performance
P1011 - Fuel Pump Delivery Pressure Too Low
P1012 - Fuel Pump Delivery Pressure Too High
P1191 - Inlet Air Temperature Sensor Rational/performance
P1192 - Inlet Air Temperature Sensor Low
P1193 - Inlet Air Temperature Sensor High
P113c-o2 Sensor Power Supply Circuit Performance
P125a-power Enable Control Circuit Low
P125b-power Enable Control Circuit High
P1272-a/c Clutch Control Circuit 2 Low (tipm)
P1273-a/c Clutch Control Circuit 2 High (tipm)
P1274-a/c Clutch Control Circuit 2 Open (tipm)
P1275-a/c Clutch Control Circuit 2 Overcurrent (tipm)
P1277-starter Control Circuit 2 Low (tipm)
P1278-starter Control Circuit 2 High (tipm)
P1279-starter Control Circuit 2 Open (tipm)
P127a-starter Control Circuit 2 Overcurrent (tipm)
P127c-fuel Pump Control Circuit 2 Low (tipm)
P127d-fuel Pump Control Circuit 2 High (tipm)
P127e-fuel Pump Control Circuit 2 Open (tipm)
P127f-fuel Pump Control Circuit 2 Overcurrent (tipm)
P141a-exhaust Gas Temperature Sensor 1 And 2 Signals Swapped
P144e-egr Cooler Bypass Status Line Circuit Low
P144f-egr Cooler Bypass Status Line Circuit High
P1451-diesel Particulate Filter System Performance
P1484-catalyst Overheat Detection
P1506-crankcase Depression Regulator Valve Performance
P1507-crankcase Filter Restriction
P1508-crankcase Filter Restriction - Replace Filter
P2000-nox Absorber Efficiency Below Threshold - Bank 1
P2002-diesel Particulate Filter Efficiency Below Threshold
P200c-diesel Particulate Filter Over Temperature - Bank 1
P200e-catalyst System Over Temperature - Bank 1
P2032-exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 2
P2033-exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 2
P2080-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 1
P2084-exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 2
