6.7l Cummins mods in California? Options.....
Discussion in 'Engine and Performance' started by swp1983, Sep 23, 2016.
Sponsored By: Moe's Performance
  1. swp1983
    swp1983 Junior Member
    34
    23
    Jul 2, 2016
    Ram Year:
    Engine:
    6.7l cummins
    I've searched a lot so don't hammer me for not looking. Seems like most of you guys are not in California. I know I'm limited on what I can do in Cali for performance/ mpg. But what are my fellow Cali neighbors doing to their 6.7s? Sounds like I may get away with an egr deleat, intake and a tune( but go back stock for smog)?? School me up please
    2012 2500 cummins in So. Cali!
    Thanks fellas
  2. brandonjansen
    brandonjansen Senior Member
    1,689
    901
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    Do you have to do smog testing every year? Is there a way around that? I know of a number of Cummins trucks in Cali that are fully deleted but I'm not sure how they're getting around the smog testing. If you have instagram I could get you some of their usernames to PM and ask what they're doing.
  3. swp1983
    34
    23
    Jul 2, 2016
    Ram Year:
    Engine:
    6.7l cummins
    Pm sent thank
  4. Bluesmoke91
    Bluesmoke91 2nd GEN Site Mod Staff Member
    3,160
    233
    Nov 26, 2010
    Baldwin Park, California
    Ram Year:
    Engine:
    I'm in CA with a straight piped 5.9. Havn't had to smog yet and not too sure where to go either. Keep me updated
    Sent from my SM-G900V using Tapatalk
  5. swp1983
    34
    23
    Jul 2, 2016
    Ram Year:
    Engine:
    6.7l cummins
    sounds like you need to know some people to get around it and evan then its a risk. But yours is a 5.9, isn't it easier to take off and put on the stock equipment?.... no particulate filter... I feel lucky that i don't have to put in def fluid in but the '12 still has alot of emissions crap on it that I'm still learning about... I'm trying to track down someone in my town that had 6.7l mods to see what they do locally...
  6. Power247
    Power247 Senior Member
    42
    5,502
    809
    Jul 26, 2012
    High Point, NC
    Ram Year:
    Engine:
    CTD 6.7
    If you delete, expect to have to but everything back on before you go in for inspection. You can remove just the DPF and NOx canisters and replace with a delete pipe to simplify the process. The delete tuners er will disable the EGR so reason to remove it from the truck.
    There are options for those looking for a little more power and drivability and don't want to have to delete. Ray at Double R Diesel is working on emissions intact tuning on the new RaceME MM3 platform but not sure if it's ready to go yet. I'm sure that some of the bigger name EFI live tuners have emissions intact tuning as well.
    Greg
    2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
    2016 | Heartland Pioneer | DS310
  7. R/T_Fire
    R/T_Fire Senior Member
    37
    3,398
    1,157
    Feb 3, 2015
    Pleasant Grove
    Ram Year:
    Engine:
    Where are you located? Some very Rural areas do not require smog maybe you are lucky and in one of those areas.
    But other than that you have a few options to run rebel and get a "hot smog", which is not something I would suggest. Honestly there isn't much you can do to these things that Comyfornia allows.
    As you mentioned anything where the smog equipment is removed you would have to replace at time of smog. That even goes for turbos, they have become wise to what the stock ones look like and many smog shops and State referee look at model numbers now. Some may sneak through though.
    But it is merely a visual test for parts compliance and a wrap test to see if it smokes. Its more about control and $$$$ A Buddy of mine just got red tagged recently for his turbo on his second gen. had to change everything back to 100% smog to get his registration. Smog shop turned him in. Funny thing is it smoked more with the stock set up than it does with what was modified to it.
Share This Page
