74 d-200
Discussion in 'Suspension' started by Dodgewade, Jan 21, 2017.
  1. Dodgewade
    Dodgewade Junior Member
    60
    Jan 21, 2017
    Ram Year:
    1975
    Engine:
    318
    I have a 74 D-200 that will need the front suspension built in the near future. Now, I also have a 76 D-300 that I would like to use the front spindles from. Since I'm going to rebuild a front end I had rather build the D-300, since it is set up for a single duel wheel. I put a Dana 60 or 70 with duel wheels under the rear a few years ago. It would be good to match the wheels.
    Has anyone done such a swap? Any input? Can I just change the ball joints and spindles? Any known opportunities with such a swap?
    Thanks in advance for any info. Got to get started on this one direction or the other.
    Wade
  2. crazzywolfie
    crazzywolfie Senior Member
    14,160
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    if both have disk brakes i would probably just try swapping 1 of the rotors over. i am pretty sure the spindles are likely the same or very similar.
Share This Page
