Starting New Thread...
OK so, this may or may not be related to the update. All was well for me until a few days ago when the radio screen stayed blank after turning on the truck. About 5 minutes into the drive the radio turned on and operated as normal.
A few days later, the same thing happened except now the radio has remained inop (it worked again briefly for a 20 minute drive today). I have switched the in-line fuse in the engine bay, left the battery disconnected for a couple of hours and physically removed the radio and plugged it back in all to no avail.
Some things I noticed while the radio is inop 1. The premium cluster does not display the time 2. The premium cluster didn't show the compass direction but that has come back 3. I have a LockPick connected but it doesn't work with it removed either, oddly the LockPick is passing power on the accessory power to my dashcam but I cannot see its Wi-Fi connection leading me to believe the radio and LockPick are not receiving power. At other times, the LockPick is not passing power to the dashcam. It appears (maybe) that if the Compass direction is not working, the accessory power to my dashcam may also not be working. I can adjust the HVAC with the hard buttons (blower speed, temperature, defrost) but the A/C button will not lite up when this issue occurs.
I really have yet to find a pattern but I believe the issue is that the truck is not supplying power to the radio when this issue occurs and don't think that it's the radio itself at fault (though I could be wrong). I will say that the radio is not working most of the time but when it does it works perfectly.
Any ideas? Is there more than one radio fuse? I know someone had a similar problem but I can't remember if it was for this update as these threads get pretty long.
Thanks in advance...
