8 Speed 8PH70 Question
Discussion in 'Engine & Performance' started by SyN, May 16, 2014.
Sponsored By: Moe's Performance
  1. lonewolf2873
    lonewolf2873 Senior Member
    44
    413
    95
    Feb 17, 2014
    Rochester Hills, Michigan
    Ram Year:
    2014 Ram Crew Cab 4x4
    Engine:
    Well you didn't say you had the Hemi and was asking if you knew which trans.
    We have very knowledgeable to lucky the can fill gas tank newbies. Didn't know where you fell in equation, since you called trans 8ph and didn't want to insult.
    Had heard anything on serviceability of 8hp70 trans.
  2. jcat
    jcat Senior Member
    446
    123
    May 3, 2014
    Ram Year:
    Engine:
    Yet his info under his name and his signature line both say hemi...
    Truth be told I don't buy the whole lifetime fluid thing either, but the powertrain is warrantied up to 100k. If the fluid deteriorates and the trans gives up the ghost, it is most likely going to happen within 100k.
    The problem won't be draining the pan or changing the filter, it will be filling it back up with fluid. Unless there is a fill plug located in an accessible area you may be looking at dropping the trans to do a fluid swap.
  3. BlownGP
    BlownGP Senior Member
    5,655
    1,292
    Feb 10, 2013
    Houston/Baton Rouge
    Ram Year:
    2009 RAM CC Sport
    Engine:
    Like a few cars I've seen with no dip sticks. There is a plug on the case you can fill it at. Again not sure about this trans. It is a bitch to fill though, I had to do it on my brothers G6.
    I understand the lifetime fluid thing which is great, but I hate cars with no tranny dipstick.
  4. lonewolf2873
    44
    413
    95
    Feb 17, 2014
    Ram Year:
    Engine:
    Heya smart guy, he didn't have hemi anywhere in his signature or under his name when he posted.
    It's better to keep your mouth shut and be assumed an idiot than open your mouth and prove it!
    I responded to help a fellow member with a question he asked. Did you come to help or criticize?
  5. loveracing1988
    loveracing1988 Senior Member
    3,392
    844
    Jul 4, 2013
    Clarkston, MI
    Ram Year:
    Engine:
    Regardless of which transmission he has, both are 8 speeds, both have "lifetime" fluid, both do not have a dip stick, and both have the plastic pan. So a answer for one will be the answer for both.
  6. jcat
    jcat Senior Member
    446
    123
    May 3, 2014
    Ram Year:
    Engine:
    :rolleyes:
  7. lonewolf2873
    44
    413
    95
    Feb 17, 2014
    Ram Year:
    Engine:
    Lol
  8. lonewolf2873
    44
    413
    95
    Feb 17, 2014
    Ram Year:
    Engine:
    It's personal preference I suppose, I could sleep better at night knowing I had the German made 8HP. No real proof there is anything wrong with the 845re but it's newer and not nearly tried and true.
  9. jcat
    jcat Senior Member
    446
    123
    May 3, 2014
    Ram Year:
    Engine:
    The 845re is just an 8hp45 renamed to fit Chrysler standard. I detailed the differences in the other thread but it basically just cant handle as much torque as the 8hp70. I think it was like 350 lbft vs 500 lbft rating.
    Sent from my SCH-I545 using Tapatalk
  10. SyN
    SyN 6.7L CTD Owner
    2,227
    2,581
    May 6, 2014
    Tornado Alley
    Ram Year:
    Engine:
    6.7L CTD
    Lonewolf: Thanks for all you input! My transmission I was asking about it Posted in the Title of my Thread.
    Thanks guys for all your thoughts.
    I have gone straight to the Horse for the info I needed--->ZF Friedrichshafen {ZF Services}.
Share This Page
