How come are you doing the fluid change? Also do you have the necessary tools to make sure your level is good?I have a 2014 4x4 and doing a transmission filter change. The exhaust cross pipe is completely blocking the drain and one of the bolts. Should I have to take the exhaust off?
It's not a 6 speed.
8 speeds are filled for life per Chrysler specs
Sent from my SM-G955W using Tapatalk
I changed mine, and had trouble with it ever since. Changing hard, shuddering worse than ever. Took it to the Dodge place finally. they aske me what fluid I put in there and I told them I went to the auto parts store they said this was the only one to put. Well they gave me the wrong fluid. I going to this weekend try to change and do a whole system redneck style and see if I can get all the fluid out and then drop the pan and change pan and filter again. then add the expensive fluid back. Dodge place said that auto part store owes me a transmission. But I bet I would have a hard time getting that worked out. Thought about can you keep drain plug off and leave truck running on gear would that drain all the fluid out or do I need to take line going to the oil cooler and opening it there ? 1st time try. I have a 2014 with 300+ miles on it. So to me if I screw it up, I am really not out anything. I got to get a transmission or hopes this works. Then I can't decide to get one from the dealer or junk yard with a truck with that many miles. Still a great running truck. Transmission was fine until the wrong fluid.
