Hi. I'm Adam from Bentonville Arkansas, formerly from Arvada Colorado.
My first post here and I'll try to keep it together but no promises.
I happen to have one abused, cannibalized and bastardized truck. It's been through salt rats squirrels and the poor mechanical skills of the previous owner. Anyways....
I am trying to go back to the original style exhaust since headers were requiring more work than I wanted and this aint no hotrod anyways.
It had the passenger manifold cracked, bolts and studs stripped broke loose or missing and both manifolds corroded from exhaust leaks. The entire exhaust system was loose and rusted.
I purchased a cat back single exhaust from summit minus the cat convertor and a pair of new cast iron exhaust manifolds.
Here is the problem. The driver side has the cupped outlet on the flange end and the passenger side requires a donut gasket since it is flat faced and no one seems to show a listing for the part number. The other problem being that I'm skeptical about the drivers side not having a gasket and relying solely on the cupped end of the y pipe to seal against the cupped end of the exhaust flange.
I'm debating on taking the old drivers manifold since it doesn't seem cracked and putting it on the passenger side since it doesn't require a donut. My other thought is to buy another passenger side manifold and put it on the driver side and figure out what donut fits it.
The part store can order another passenger side manifold to get here by Wednesday but I kind of want to get my truck together. Also, the old driver side manifold flange may be distorted on the flange end because the previous owner let the exhaust run so loose that I think it damaged it to where it may not seal.
The big questions.
Should I buy the one donut to make the passenger exhaust flange seal?
Should I buy another passenger side manifold with the flat exit end to put on the driver side?
Should I take off the new passenger side manifold and put on the old Driver side manifold that has the cupped exit on the flange?
What is the part number for that donut gasket for the flange?
Do the cup style flanges that require no gasket really seal or am I better off using the flat style and the donut for the exhaust flange.
Sorry, no pics because I cracked my cell screen in my pocket while fighting this bad boy.
Any help appreciated, surely somebody knows what I'm talking about and has had this problem.
-Adam
The big questions.
-Adam
