87 d150 hard shift into drive
Discussion in 'Engine & Performance' started by Kemajors, Sep 8, 2016.
Sponsored By: Moe's Performance
  1. Kemajors
    Kemajors Junior Member
    Sep 8, 2016
    Ram Year:
    1987
    Engine:
    318
    Hi everyone! First time post here
    I have an 87 d150 318 with a-904 transmission. My problem is that when I shif into drive it's a bang/hard shift and jump. U joints good, rear end just got rebuilt and is good. Entire truck is stock. All other shifting is smooth. Problem only happens when I shift into drive weather it be from park or from reverse. Thank you in advance for any help!!
  2. crazzywolfie
    crazzywolfie Senior Member
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    have you checked your motor mounts? i would be mainly inspecting the drivers side one
  3. Kemajors
    Sep 8, 2016
    Ram Year:
    1987
    Engine:
    318
    Thanks for the suggestion! Just checked and engine mounts are in good shape
  4. crazzywolfie
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    have you check the fluid level in the transmission with the engine running and the truck in neutral?
  5. Kemajors
    Sep 8, 2016
    Ram Year:
    1987
    Engine:
    318
    The transmission was just services for 100k maintenance but I went ahead and checked anyway. Fluid is a nice pink and at the proper level
Share This Page
