91 1/2 ton 4 wheel drive manual trans
Discussion in 'Tech Info' started by Brewsky, Sep 23, 2014.
  1. Brewsky
    Brewsky Junior Member
    Sep 23, 2014
    Ram Year:
    1991
    Engine:
    318
    Had a bearing go bad on main shaft changed it out and now clutch won't work. Have vacuum on slave cylinder 5 times even tried pumping several days and still have to shut truck off to stop it. What happened clutch is not even half wore bearing was correct cost 200 dollars any know I need help
Share This Page
