97 Dodge Dying Problems
danfirey
Hey guys. First time posting here but I've used your forum to fix MANY things in the past. But now I'm at an impasse. My truck has had this annoying intermittent dying issue that doesn't seem to go away.
What it does is when in driving under 35 mph, only sometimes the truck will not hold an idle. It's like something isn't communicating. Once I run it high, the problem goes away! But this doesn't happen every day.
I've noticed I also consume oil. Maybe plenum?
Maybe O2 sensors?
What I've replaced
IAC
TPS
AIR FILTER
CLEANED BATTERY TERMINALS
Once I did these things, the problem went away for a while. But i cleared the PCS while doing so. Never once got a check engine light.
Let me know if you have had this problem. Thanks!
Davesan
Maybe O2 sensors?
What I've replaced
IAC
TPS
AIR FILTER
My fuel pump went out and had no check engine light.
