98 3500 cluster help
Discussion in 'General Discussion' started by B1gch1n0, Nov 28, 2016.
  1. B1gch1n0
    B1gch1n0 Junior Member
    Nov 27, 2016
    Ram Year:
    98
    Engine:
    5.9
    I have a 98 3500 5.9 td. The dash cluster does not work other then the tach, is there somewhere I can look to fix it? I checked fuses, nothing seams to be for the cluster tho.
  2. dapepper9
    dapepper9 Senior Member
    22
    4,773
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Grounds would be a good place to start
    B1gch1n0 likes this.
  3. Ramtech2319
    Ramtech2319 Member
    59
    23
    Nov 29, 2016
    Ram Year:
    Engine:
    Did you do a cluster test?
  4. Ramtech2319
    Ramtech2319 Member
    59
    23
    Nov 29, 2016
    Ram Year:
    Engine:
    Before the key is I. The ignition hold the mileage reset button down on the cluster hold it in while holding it turn key to on position and u should see all the gauges start to move and release if all gauges work it's the truck not the cluster
Share This Page
