A/C is out!!! Tips and ideas?.
94singlecab
5.2 Magnum
My a/c went out and want to get it fix. I want to figure out what might be the problem, before heading out to shop to get it checked out. I have 01 1500, since i got the truck the a/c worked fine. Now it just blows out hot air. Only time it will blow cold air is in the moring on its first start of the day, but after wormed up it will slowly begins to start blow hot air. Any ideas or pointers on what i should check. Please and thanks in advance.
Joe w.
Virginia
318 5.2l
May just need to be recharged. Hopefully it's not the a/c compressor
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Make sure the compressor is engaging. If it is, put a set of gauges on it and see what you have to work with.
Being a 94, it might have the original compressor and it might be losing its will to live.
BeauDuke01
mine did the same thing, and the air gap in the compressor was off, they adjusted it and it works like a champ.
clownprince
Magnum V8
Check the fuses first!!!!!! If I blow the horn it blows the fuse for the AC
94singlecab
5.2 Magnum
Thanks for the advice plan on checking all out this weekend. Hope its just something small.
94singlecab
5.2 Magnum
Its not a 94, its 01.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Get a can of refrigerant with dye and look around for green crap blowing out.
its less than $15 and shows if there is an external leak.
David H
USA RET
Minneapolis
The easiest fix I can think of is that your temp selector is in the warm position. Happens to me every year.
