jvsutton
- Jul 18, 2014
- 12
- 2
- 1999
- 3.9
I have an intermittent problem with my compressor. It will work sometimes for days, sometimes for only about 15 minutes then it'll stop cycling. Seems to be totally random and has nothing to do with outside temps. Sometimes after I kill the truck and then start it again it'll work for a while, but always stops and blows ambient temp air.
I tried disconnecting the low pressure switch and jumping it. When I jumped it I noticed the engine speed raised, but the clutch didn't engage. So I checked the wiring at the connector to see if it was getting 12 volts, it would periodically show some voltage, and sometimes be nothing??? I know you aren't supposed to throw parts at problems, but I went ahead and bought a new a/c clutch relay for the underhood fuse box just incase that was the problem and wasn't supplying constant power to the low pressure switch. Well it wasn't because it's still acting up. I have looked for a wiring diagram to see how the switches are wired and where they get their power from, but can't find anything.
When the compressor is running the air is plenty cold and my pressures at 83^ outside show on the gauges as steady 40 on the low side, 175 on the high side. So my pressures seems fine to me, I just can't figure out why the stupid clutch won't stay engaged.
Should the connectors to the pressure switches, both low and high sides have 12 volts in?
Sorry for the long winded story, but I hope some of you have some ideas.
The truck is a 99 1500 V6 2WD.
