Ac comprssor?
goodtodoo
1996 indy pace truck
So now the cold weather is coming back and I used the heater for the first time in a long time. But my compressor keeps kicking in and out, what would cause that? Thanks.
Gr8bawana
6.7 CTD
I believe it does that normally when it is in defrost mode.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
The A/C compressor is supposed to work in all defrost positions as well as the A/C settings. The purpose of running in the defrost settings is to first cool the air to remove moisture then heat the dry air to pull condensation off the window.
G
goodtodoo
OK. Thanks guys. Its not very often I use the heat in this truck.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Dudeman is correct, the compressor cycles about every 20-30 seconds.
