ac/heat question
Discussion in 'General Discussions' started by tim johnson, Mar 26, 2012.
  1. tim johnson
    tim johnson Member
    38
    Oct 30, 2011
    Gallatin, TN
    Ram Year:
    Engine:
    4.7
    07 Ram 1500 QC 5.7 Hemi
    What would cause the temp of the drivers vents to be warmer than the temp of the passengers vents? Charged my ac yesterday and there is a very noticeable difference.
  2. HemiBabe
    HemiBabe Senior Member
    29
    7,215
    854
    Dec 6, 2010
    DFW
    Ram Year:
    Engine:
    Hmm... I'm not sure but I bet someone will know shortly
  3. TexasRammer
    TexasRammer Supporting Member
    4,093
    296
    Dec 29, 2011
    College Station, TX
    Ram Year:
    2002
    Engine:
    4.7
    do you have the dual climate control?
  4. reefguy89
    reefguy89 Senior Member
    28
    3,388
    109
    Jun 30, 2010
    laurel de
    Ram Year:
    Engine:
    Blend door possibly. How did you charge your ac? With one of those kits from the parts store. If so why?
  5. tim johnson
    tim johnson Member
    38
    Oct 30, 2011
    Gallatin, TN
    Ram Year:
    Engine:
    4.7
    Negative
  6. tim johnson
    tim johnson Member
    38
    Oct 30, 2011
    Gallatin, TN
    Ram Year:
    Engine:
    4.7
    I charged my ac with a set of snap op gauges, pulled a vacuum on it for about 3 hours before hand. I swapped motors in this truck last winter and had to evacuate the system to remove the compressor. I am just now getting around to charging it again.
  7. reefguy89
    28
    3,388
    109
    Jun 30, 2010
    laurel de
    Ram Year:
    Engine:
    Did you put in a new drier? Also look up the blend door problem.
    http://www.heatertreater.net/index.html
  8. tim johnson
    tim johnson Member
    38
    Oct 30, 2011
    Gallatin, TN
    Ram Year:
    Engine:
    4.7
    No, they drier was replaced early last year so I did not change it.
Share This Page
