Adding footwell lighting on 2016 express
abouttobeglue
I have the unused plugs on the wiring harnesses, got the bracket on the driver side and indention on the passenger kick plate, im a little confused as to the part # i need and which setup, seen people use the bulb sockets for the jeeps as well, also do i need to buy bulbs separately, and will i have to have it flashed by dealer?
BiGMERF
2017 SLT 4x4
v6
why not just add some led strips yourself ?
kad
Hudson Valley, NY
5.7L HEMI
If you use the OEM LED ones, you will not need bulbs. If you use the Jeep ones then you will need them. Neither will require a dealer flash. Note, the OEM LED ones have permanent LEDs in them, they are not socketed and cannot be changed. If you want a different color than the OEM warm white, you will need to use the Jeep ones and your choice of bulbs.
OEM LED kit (lights & Bezels) - https://www.allmoparparts.com/sku/ramfootlight.html
Jeep sockets - https://parts.moparonlineparts.com/oem-parts/mopar-lamp-courtesy-68395784aa
-K
abouttobeglue
abouttobeglue
Appreciate it kad, think ill see if the dealer has the jeep part#s available.
VB712
Maxi_built
Va Beach
I have the factory warm led floor lights on my sport and they suck to say the least. Adding led strips today.
WTM75
Upstate NY
3.6 Pentastar
I put the jeep ones in last week, they includes the bulbs. I did change them out to LEDs to match the rest of my interior lights.
kad
Hudson Valley, NY
5.7L HEMI
The bulbs they included, they were incandescent though, right? Not LED?
-K
abouttobeglue
abouttobeglue
Went with the jeep kit, 15 bucks apiece from the dealer, 16 bucks for some 194 blue leds.
RoadRamblerNJ
Knoxville, TN
392 Hemi
That is correct. I used these
https://www.amazon.com/gp/product/B00JRE38EA/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
I used these in every area that would accept these bulbs, including the licence plate bulbs with no codes.
Same ones I used!
No problems at all.
I used the Red ones for dome and map lights (Red does not ruin your night vision).
I also used Red in my brake/running lights. They are way brighter than before.
WTM75
Upstate NY
3.6 Pentastar
I’ve been thinking about switching to the red myself. What did you use for the back bulb, festoon?
radikio
