Adjusting billsteins on the truck?
Discussion in 'Lifted' started by chrisc75, Jan 10, 2017.
  1. chrisc75
    chrisc75 Member
    45
    27
    Dec 30, 2016
    Delran NJ
    Ram Year:
    Engine:
    just wondering if anyone has been able to compress the spring enough on the truck to adjust the height. sitting at 2.1 right now but would like to level out the truck some more and get them up to 2.8
    Edit: Also would like to mention m sitting on a 6in rc lift so there also a additional spacer ontop of the strut
  2. WilliamS
    WilliamS Senior Member
    35
    1,262
    312
    May 3, 2016
    Ram Year:
    Engine:
    I dont know if you can. You would have to put the truck on stands, remove the tires, and have an impressive spring compressor setup. Im sure it can be done but man I wouldnt want to be anywhere near it.
    On a side note, if you do get it to work, post it up I want to see!
  3. nclark112
    nclark112 Senior Member
    175
    60
    Dec 2, 2015
    Jacksonville, NC
    Ram Year:
    Engine:
    I've gone through this idea in my head cause I'm at 2.1 and want to go up too but I just don't see a way to do it in the way of I don't see how to fit compressors in there. It's a pretty tight squeeze.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  4. brandonjansen
    brandonjansen Senior Member
    1,689
    901
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    You'll never get it compressed enough to get up in there and actually move the C-clip. If you look at how the adapter ring and lower spring seat extend down over the C-clip you'll see what I'm talking about. Plus, as stated above, you'll have a really hard time getting a spring compressor up in there in the first place.
    With the amount you'd screw around trying to do it that way you're far better off just taking them off to begin with. Really it's not that hard to get the struts out of the truck completely.
  5. Jershipe
    Jershipe Senior Member
    41
    259
    74
    Nov 5, 2016
    Monroe Michigan
    Ram Year:
    Engine:
    I tried it when mine where at 2.1. I tried to compress them off the truck enough to move them down to 1.4 and I couldn't. I don't think it's possible on the truck.
  6. chrisc75
    chrisc75 Member
    45
    27
    Dec 30, 2016
    Delran NJ
    Ram Year:
    Engine:
    figured it wasn't possible but figured id ask to see if someone somehow found a way to do it lol
  7. Drummin4jc
    Drummin4jc Senior Member
    2,169
    869
    Feb 3, 2015
    SW Pennsylvania
    Ram Year:
    2012 RAM 1500 Express QC
    Engine:
    I was wondering this same thing as well. I figured it wouldn't be a good route to take but I'm glad your posted and got some responses. :)
    Adam
  8. chrisc75
    chrisc75 Member
    45
    27
    Dec 30, 2016
    Delran NJ
    Ram Year:
    Engine:
    doesnt hurt to dream right hahahaha
  9. mpittman
    mpittman Senior Member
    222
    70
    Aug 5, 2016
    Indiana
    Ram Year:
    2015 Big Horn Crew Cab
    Engine:
    I was thinking the same thing.... even if somehow you got the spring compressor jammed in there, that thing would be a ticking time bomb and a death trap!! :)
Share This Page
