Advice, please
Discussion in 'Engine & Performance' started by Truemagnum15, Jan 1, 2017.
Sponsored By: Moe's Performance
  1. Truemagnum15
    Truemagnum15 Junior Member
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    We have a 1999 dodge ram 1500 5.9L V8. My husband recently had his engine remanufactured. He got the engine back into the truck and started it, but it would not idle. It died as soon as he took his foot off of the gas. The truck was running maybe two minutes total
    When he checked the oil, he found a thick, milky substance on the dipstick. I have always been told that indicated blown head gaskets. Is there anything else it could indicate? How can he have blown head gaskets when he just paid $2100 to have the engine remanufactured?
  2. Markcuda
    Markcuda Senior Member
    59
    493
    225
    Nov 16, 2016
    Clinton,Illinois
    Ram Year:
    2015-Laramie-1500-CC-4X4
    Engine:
    Drain the oil and see what is looks like.
  3. Joe w.
    Joe w. Senior Member
    359
    56
    Aug 12, 2015
    Virginia
    Ram Year:
    1999
    Engine:
    318 5.2l
    Moisture in your oil I have seen that before and wasn't a blown head gasket. Like Markcuda said drain your oil and see what it looks like
  4. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    Thank you Any ideas why it will not idle? It starts just fine and runs as long as he does not let off the gas
  5. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,856
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Download the factory service manual here in the tech section. Have him read through the distributor procedures, particularly the part about fuel sync and alignment. Highly possible that's not set. If the rotor is in cyl 1 at the right time (you'll understand after reading) then don't screw with it.
    After that I'd look at tb sensors
    gofishn likes this.
  6. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    We did download the manual some time back. He did say he was glad he had the distributor in right because it is a bitch to try to do anything with it once it is back in the truck as it is underneath the dash part so close to the firewall. I will tell him to check the tb sensors. Thank you. Everyone has been a tremendous help these past few weeks. My husband was a papermaker for over 31 years and the so called friend that was helping him with his engine decided not to come back when it was time to install it. It has taken since December 13th, but we can finally see the light at the end of the tunnel. Thanks again all who have responded to my posts. It is truly appreciated. I wish you all a very happy New Year.
  7. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    My husband would like to know what a tb sensor is, please
  8. dapepper9
    22
    4,779
    1,856
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Sorry about that, i have a bad habit of abbreviating things that are commonly mentioned while forgetting not everybody is as familiar with stuff.
    Tb is the throttle body. Hesitant/rough idle like you described is often caused by the Idle Air Control motor (iac) or the Throttle Position Sensor (tps). Iac controls air going into the engine at idle by using am electric motor to gauge the amount of air that needs to go in. Tps does exactly as it sounds, senses throttle position. Pcm (computer) uses this information in determining fuel and timing. Sometimes the iac doesn't quite open enough or the tps detects throttle input when there is none.
    Iac will be on the back of the throttle body and tps will be on the driverside. Personally I'd probably start with the iac because if it's dying after he takes his foot off the pedal, it sounds like the tps is doing its job but when the iac is supposed to take over, it's not.
  9. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    Thank you
  10. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    Is there a way to check the iac?
Share This Page
