After market headlights
Louis Males
Winkler, Manitoba
Which after market headlights for a 1999 dodge ram 1500 do you recommend? Looking for a set that can be adjusted without having to remove them.
L
Louis Males
Winkler, Manitoba
Thanks for reply but doesn't help me much. Looking for specific info like brand and May be a link to purchase.
dapepper9
Iowa/Nebraska Border
5.9L V8
Here's the thing: all your aftermarket lights are pretty much made by the same 2 or 3 manufacturers and labeled differently. Ebay, amazon, brand name etc doesn't matter. All the same. Just hop on ebay and search "dodge ram headlights 2pc". It'll get ya there
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
for the record, all of the original headlights would have to be removed and then new ones installed. for adjustments they should be same as long as 2 piece used.
L
Louis Males
Winkler, Manitoba
Was really hoping to find an aftermarket that could be adjusted while installed. This removing to adjust is a real pain. Worse design I have ever seen
dapepper9
5.9L V8
2pc can be adjusted while installed. They're basically factory without the frosted lens. Clear lens instead. Adjust the same though
L
Louis Males
Winkler, Manitoba
In order for me to adjust up and down I have to remove... pop a clip to get to adjustme t screw. Put it back together and see if I did enough. If not ... start all over again. What ever happen to using a Philips and being able to adjust on roadside to it was right.
L
Louis Males
Winkler, Manitoba
So what am I missing. With the factory there is a plastic piece blocking screwhead and a clip that keeps the screwhead lowered behind it. If you are right I have been removing the whole thing without needing. Anyway you can direct me to a webpage showing me
