Air Bag Kit or Helper Springs?
Discussion in 'Towing & Hauling' started by IQRaceworks, Oct 13, 2016.
  1. IQRaceworks
    IQRaceworks Junior Member
    40
    20
    Apr 6, 2016
    Ram Year:
    Engine:
    The rear of my 04’ Ram 1500 sags quite bit when I hook up my 19ft travel trailer to the hitch….even with the load distribution bars being fully torqued down. I think some of the problem might be that my truck has been “leveled”, so the front sits a little higher than a stock truck…..witch makes the rear squat look that much worse. I’m sure some of the problem could just be that the rear springs are old, and worn out.
    I’m looking for some options to stiffen the rear suspension up a little bit when I’m towing my camper and boat. From what I’ve seen…I have a few options. Either an air bag kit, or some helper springs (firestone assist springs).
    Are there any other options I should look at?
    What’s the best option?
  2. Mega-Hemi
    Mega-Hemi Senior Member
    1,134
    216
    Jun 28, 2010
    Back in New York!
    Ram Year:
    Engine:
    Cummins 6.7
    I'd go with the bags. But that's just my opinion. Had them on my last 2 trucks. What I like about them over the add-a-leafs is they're adjustable and don't stiffen the ride at all. I feel it actually rides smoother when empty. Just keep 5psi in the bags when you're not towing.
    EDIT: Just went back and re-read your post. I see you said assist springs, not add-a-leafs. I have no experience with their assist springs. I'd probably still go with the bags though. IMO.
  3. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    Bags for sure! I had bags on my Tacoma and they were great. I've ridden in trucks with helpers and it's way to stiff.
  4. bcbouy
    bcbouy Senior Member
    1,084
    398
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    i gots both.firestones and supersprings.had the supersprings,then added a level,then needed the bags to even it out when the camper's on and never bothered to remove the supersprings.they're a progressive so they don't affect the ride without a load.
  5. Jimmy68
    Jimmy68 Senior Member
    1,402
    633
    Aug 30, 2015
    Lethbridge Alberta Canada
    Ram Year:
    2001
    Engine:
    5.2L Magnum
    Love my bags in my 01 1500.
  6. MADDOG
    MADDOG Super Moderator Staff Member
    7,138
    1,881
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    I agree..go with the bags. You can't adjust helper springs to suit your needs, load or unloaded rake. Bags are adjustable.
  7. Bullitt5339
    Bullitt5339 Senior Member
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    Bags are the way to go. I have had 2300lbs in my bed with 90psi in the helper bags.
  8. airdrianify99
    airdrianify99 Junior Member
    37
    19
    Nov 6, 2016
    Ram Year:
    Engine:
    I used helper springs before.... NVR again stiff ride
    Sent from my SM-G900V using Tapatalk
  9. Rhett5.7
    Rhett5.7 Junior Member
    Apr 26, 2017
    Ram Year:
    2005
    Engine:
    No, the problem is that you have basically car suspension on a truck with a 1500. It's designed to pull bass boats, not real loads.
    69GWC likes this.
  10. Rhett5.7
    Apr 26, 2017
    Ram Year:
    2005
    Engine:
    I've had 5000 Lbs in a 2005 2500 and it dropped maybe 3 inches if that from original sitting position.
    We have a 2003 3500 with helpers that have had 7000+ in the bed and it did the same.
Share This Page
