2kDodgeRam
- Jun 9, 2017
- 6
- 2
- 2000
- 5.9
I did a lot of research on this forum and found the "wild vents" thread which led me thru a lot of trouble shooting - thanks for all the tips. I replaced the check valve (only had one by the manifold, the T-connection didn't have one even though the manual shows one there) and PCV. The air still blew out the floor vents only. Then I proceeded to watching each actuator while someone ran the controls and all actuators worked which leads me to believe that I have good vacuum on all of them. However; I noticed on the Heat/Defrost Door Actuator, the Door Pivot Connection was disconnected. This one is directly behind the metal frame / airbag wiring harness on the hump. I tried reinstalling it but it wouldn't stay, I think it's too worn. I think I can reinstall a new one without removing the dash, but I can't find a part number.
Would anyone happen to know the part number of this piece?
The first impage shows the actuator with the part still attached. This was after I reattached it to the actuator arm. It is not attached the door hinge. The second image is of the part.
