Air intake puzzle
Thomas Richards
5 miles from Branson as the crow flies; 20 miles b
Background: 89 Power Ram 3/4 ton, 4WD, 360 engine, 3 speed auto. Runs well but leaks oil from left valve cover via a rubber sealed hole appr. 1 1/2". Original air intake apparatus was replaced with a chromed "pot" over the throat. To try fixing leak I recently bought a used air intake apparatus for this model but there appears to be no connector to this mysterious "hole" in the valve cover. QUESTION: is there a site where I can get a visual "blow-up" of the original parts?
muddy12
Indiana
Hole in the valve cover is where the original PCV valve connected.
If you can find an emissions diagram for it, that should show the factory parts and hose routing.
T
Thomas Richards
Thanks for response and diagrams. Do you know if I can get a blow-up engine pic from Chrysler? Before tackling this I would like to see what it SHOULD look like. Tom.
