Airbags in rear
RamRoy
Crestview, Florida
My 09 Ram with RC 6" lift sits an inch higher in front now that I had new Bilstiens put on. They installed them and said that the front was low so they bumped up the 5100s. The front was high but they said it should settle. It did not and now they say if the frame is level, it will cost me labor to adjust them. They consider level being the frame and not the actual height.
Anyway, I need to measure.... but like the little extra lift.
What options do I have for airbags in the rear springs? I see this as a possible advantage for leveling now and when I tow my boat. They told me that they cost 500-600, but I have seen others online.
Any inputs? I don't need an air compressor on board.
R
RamRoy
Crestview, Florida
Can a 1 inch spacer be put under the coil while there is a spacer on top of the coil?
6.7CumminsDrvr
The Dude abides………
Georgia
I would not put a spacer under the coil of you already have one up top.
As far as bags, if you want the bags to give a little lift you want the kind that are outside the coil like the Timber Grove units. The ones that go inside the coil push out against the coil to keep it from compressing so they can’t really “lift” the rear like the Timber Grove type can.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Timber Grove air bags are great and you can get a 1" to 2" before its going to ride bad with no weight in the back.
R
RamRoy
Crestview, Florida
Was just looking at the ICON 2 stage rear coil springs for my Ram. Supposed to give 1"-1/5" of lift and the reviews say the ride is nice with the two stage coil. Keeps the rear soft enough but has the strength for towing capacity. I only pull a 19 foot bassboat and it usually causes minimal sag.
I think the spring idea is much better than the airbag. Any thoughts or experience with these? Also, will I need to have another alignment done, or is that only needed for front end work.
http://www.socalsupertrucks.com/Icon-2009-Current-RAM-1500-1-5-Lift-Rear-Coil-Spring.aspx
