- Jun 22, 2017
- 589
- 254
- Location
- Western, Idaho
- 2013 Sport
- HEMI 5.7
Thanks for any info, I know I have been buggen you all a lot but you are so helpful and I always lean to ask my elders or experience counter parts ahhah. (I am 29 never towed anything on a personal level, just Military, pulling AN/MPQ-64 Sentinel heheh).
So, I have been doing alot of research and going down rabbit holes of youtube for installing a Weight Distribution Hitch, How they work, what they do etc.
My question is if you have both a WDH and airbags how would you hook up your trailer?
Would you hook it up, level the truck out /w air bags and then raise the trailer up and install the WDH?
or
would you hook it up enough just to have the ball and trailer aligned and install the wdh and then level the truck /w air bags?
I am leaning the first one as from I understand is ....
You level the truck with the trailer attached and then raise the trailer up, install the WDH and lower back down.
I am sure airbags and WDH is overkill but I like overkill as I want to live if something weird happens lol.
Also looking to install the sway bar that attach to the WDH from the Trailer.
Side Question 1 :.I have the stock sway bar for the Truck itself do I really need to upgrade ?
Side Question 2: What is the threshold you would not go beyond in terms of trailer weight with my Truck?
Side Question 3: What is the Absolute BEST WDH out there for us? I dont care if it costs double the average WDH. Ease of us + Security is all I care about.
Truck:
Year: 2013
model: 1500
Trim: Sport, Crew Cab
Trans: 4 x 4
Gear Ratio: 3.55
Tires: 275-55-20, XL Rated, 50 PSI
Elec Shift On Demand Transfer Case
215MM Front Axle
235MM REAR AXLE
Conventional Differential Frt Axle
Conventional Differential Rear Axle
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Rear Stabilizer Bar
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
6-Spd Automatic 65RFE Transmission
Heavy Duty Transmission Oil Cooler
Heavy Duty Engine Cooling
Electronically Controlled Throttle
Class IV Receiver Hitch
Max Payload
1333 lb (604.64 kg)
Max Towing
8500 lb (3855.54 kg)
or
Truck:
Year: 2013
model: 1500
Trans: 4 x 4
Gear Ratio: 3.55
215MM Front Axle
235MM REAR AXLE
Rear Stabilizer Bar
Max Payload
1333 lb (604.64 kg)
Max Towing
