Matzram
2007 QC LB 4x4 tow rating is 8300 max. I’m looking at campers with bunk beds and most are almost 6k or over. So whats everyone’s thoughts on the subject if I’m adding airlift air bags for towing help? Thanks in advance.
If you put bags on, make sure you set your WD after you inflate them. Otherwise, eliminating the squat by raising the rear takes tension off the WD bars, rendering them less useful for transferring weight to the front axles.
NO...You set up the WDH first and use the air bags to "fine tune" the how the truck handles the load. Using the airbags first increases the load on the rear axle and you don't transfer as much weight to the front.
Even the instructions for trucks with the factory air suspension state to put the truck in "Jack Mode" before you set up a WDH.
The video is correct (and very informative) about WD vs Airbags, but doesn’t address using them in combination. I have verified with repeated CAT scale weighs, setting up WD first and then changing airbag PSI alters the WD that I worked so hard to get just right. Adding even 5 more PSI changed the height of my rear and shifted weight back to the rear axle. With spring helper bags like the Airlift 1000 especially, they are intended to make the springs stiffer, just like if you changed the coils out for stronger ones. You wouldn’t set up your WD on stock springs, then swap out your springs for stiffer ones and expect to use the same WD setting.
If you wanted to fine tune with this method, you could intentionally use too much WD and weight on front axle, then increase airbag psi a little at a time to take weight off the front axle and get it to where you really want it.
