Alignment "issue"
Discussion in 'Lowered' started by DodgeDrew71, Jun 2, 2015.
  1. tommyboi87
    tommyboi87 Senior Member
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    All I did was install shorter springs. No drop spindles or anything special. With the 4" drop in the front, I've got a really noticeable amount of camber that's affecting my steering a little.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
  2. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    So when I lengthen the slots, would I lengthen towards the inside of the frame or would I lengthen it to the outside frame?
  3. HeavyD
    HeavyD Senior Member
    1,128
    237
    Feb 21, 2015
    Medicine Hat, Alberta - Canada
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Towards the tire.
    First thing is to loosen the camber bolts & pull the tire (a-arm) out as much as you can, & then see how much more you need toooo.
    check out the tread I made about the way I fixed mine.
    http://www.ramforum.com/f46/tire_lean_after_drop-66988/
  4. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Great write up man. Love the pictures. You have a third generation though. Does that apply to 2nd Gen too?
  5. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    does not look like it, your mounts are diff, I should have looked that up.
    how much material do you have from where the holes are towards the tires?
  6. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Enough to take about 5/16 or so. Maybe not that much.
  7. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    have you pulled the a-arm out all the way to see how it sits?
  8. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Yea, at max, I still have maybe a bit over 2 degrees of camber.
  9. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Pic?
  10. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    What do you want to see? The camber angle of my tires, or the pivot bolt slots?
Share This Page
