You also need to adjust your headlights.
Did that when I did the springs a few months ago. Thanks for the tip though!
Just swapped the rear springs and got a front end alignment. Only took about an hour with basic tools to swap rear springs.
Mcgaughys
What year is your truck? I looked at their stuff and didn't find anything for a 2016 4x4. I must have over looked it maybe. Never done this stuf before.
They don't list anything for a 4wd but the rear springs are the same and work great. If you get their 2" rear drop springs it's about a 2-2.5" drop on the rear depending on cab size on the 4wd.
Is there anyone who by chance sells 1" drop coil springs? I want to lower the rear but I also have a 7k camper I pull and with my weight distribution hitch I still have about 1" rake hooked up.
Check out Crown Suspension
I cut a coil off my stock rear springs (lowered about an 1") and noticed a few months later that the front tires where scuffing on the outside and had to have it realigned. Don't know if that had anything to do with it but it wasn't doing it before.
Dropping the rear changes your caster angle
