Another 2500 sping swap question
Discussion in 'Lifted' started by csuthrower04, Jan 2, 2017.
  1. csuthrower04
    csuthrower04 Junior Member
    17
    Oct 20, 2014
    Branchville SC
    Ram Year:
    2001
    Engine:
    5.2
    Hello all,
    I have a 2001 1500 2wd quad cab that I use as a farm/work truck. I also use it to tow a 31 foot camper for short distances (75 miles or less) across flat land. I want to improve its towing capabilities a bit as well as give it a little better stance. In the rear I am planning to add a leaf as well as put on a set of monroe coilovers. In the front I plan on installing new shocks and a set of 2500 coil springs, which leads to my question. I am going to order a new set of springs from Moog, so should i order the springs for the v8 or v10 gasser 2500? I wasnt planning on ordering the diesel springs as it is my understanding that they may lift the front end too much. Anybody have suggestions as to which set I should order? It would be great if I could get a couple of inches of lift in front without having to do any major mods other than popping in new springs and shocks. Thanks!
  2. dapepper9
    dapepper9 Senior Member
    22
    4,773
    1,855
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    V8 springs won't be any stiffer than what you have now, v10 and dsl springs are the same
  3. mda8569
    mda8569 Senior Member
    48
    140
    28
    Dec 13, 2014
    Vandalia Ohio
    Ram Year:
    2001
    Engine:
    5.9 magnum
    So the 2500 front springs are the exact same ones in the 1500?
  4. csuthrower04
    17
    Oct 20, 2014
    Branchville SC
    Ram Year:
    2001
    Engine:
    5.2
    Thanks yall. Moog makes a replacement spring for the v10/ diesel 2500. I think I'm gonna purchase a pair of these and some new shocks instead of jer king a pair out of junkyard that's 20 years old. Do yall reckon my stock control arms can handle it?
  5. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    You should be good to swap in the 2500 springs from a V-10 or diesel. There is no difference as far as i'm aware between the 1500 and 2500 mounting wise. Your front end will sit a bit higher, how high i'm not sure, mine has had the diesel set on it since I bought it.
    An add a leaf in back will raise it by less than an inch unless the back is really tired. Then it could lift it by 1in or more, but not for very long.
    The best bang for your buck would be to goto a place like rockauto or Husky and get some 5 leaf spring packs. That way you are good for your short trips, but if you do want to load it down or go for a longer trip, you won't have to worry about snapping one of the old leafs on the road.
    I paid about $350 for the pair, including shipping on a set of Husky springs.
    Thats what happened to me at least. I hit a pothole a couple hours from home with a flatbed trailer and small tractor. The rear eye snapped and the spring slammed into my bed, i'm lucky it didn't bust a hole it in.
    Now, my back end sits about a 3/4in higher in back, and there is no sway from my travel trailer. Before, I could see the axle shifting slightly when the wind would hit the trailer going down the highway.
    Just an FYI to replace the rear springs, you need to drop the tank, or at least loosen it to get access to the front mounting bolt.
  6. BBartow
    BBartow Senior Member
    5,759
    3,313
    Nov 18, 2013
    New Port Richey, Florida
    Ram Year:
    1995
    Engine:
    5.9L Magnum
    I'm not sure how much v10/dsl springs will lift it on the 2wds but if its over 2.5" you will need new upper control arms.
  7. csuthrower04
    17
    Oct 20, 2014
    Branchville SC
    Ram Year:
    2001
    Engine:
    5.2
    Thanks for the input yall. Dudeman2009 I am gonna take your advice and get a 5 pack of leaf springs for the rear. Did you buy the Husky's off or rockauto? Also is your 1500 a 2wd?
Share This Page
