Any way these will fit?
Discussion in 'Exterior' started by jethro 03, Dec 29, 2016.
Sponsored By: BAK Factory Outlet
  1. jethro 03
    jethro 03 Member
    69
    Dec 27, 2013
    Jersey
    Ram Year:
    2008
    Engine:
    I know this is a beat to death question, but I've been looking a long time and can't find an answer.
    I found a set of wheels and tires that are exactly what I'm looking for, used.
    Ok, I have a 2008 ram 1500 quad cab big horn 4wd. It is leveled. The wheels are 20 x 10 -25 offset with 295/60 20 copper muds.
    I'm worried that they'll rub more than I can trim. And yes, I know they'll stick out quite a bit. If anyone has any pictures, that would be great as well.
    Sent from my SM-G935T using Tapatalk
  2. e_hartzell17
    e_hartzell17 Senior Member
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    They won't stick out as much as you think I have a 2001 with -24 and they barely stick out yours will stick out maybe 3" or less and they might not even run at all
  3. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    I'll have a better pic soon
    Ethan0524 likes this.
  4. jethro 03
    jethro 03 Member
    69
    Dec 27, 2013
    Jersey
    Ram Year:
    2008
    Engine:
    Thanks for the reply. I'm leaning towards getting them. I have looked online a lot and seen a few with the same sizes that fit. Most even say with no rub, but who knows
  5. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    You'll be fine they'll work fine with literally little to no run at all if any
  6. jethro 03
    jethro 03 Member
    69
    Dec 27, 2013
    Jersey
    Ram Year:
    2008
    Engine:
    I actually like them sticking out. And I don't mind trimming at all if need be, just don't want to rip my fender off or not get them to fit at all.
  7. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    I know the feeling with style come sacrifice lol -24 will be perfect
  8. jethro 03
    jethro 03 Member
    69
    Dec 27, 2013
    Jersey
    Ram Year:
    2008
    Engine:
    I'm pulling the trigger on em, but have to wait for the guy to get his new set in. More time to contemplate I guess lol.
    Thanks for the replies and the pic. I'll post what happens in a couple weeks when I get them.
  9. brandonjansen
    brandonjansen Senior Member
    1,689
    901
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    You can definitely make them fit. It will require trimming but it will work.
  10. PdPuNOme
    PdPuNOme Senior Member
    159
    11
    May 6, 2012
    Jersey
    Ram Year:
    2006
    Engine:
    I have srt10 22x10 -24 offset rims with 305/45/22 at's and I can say I ended up putting 1" bora wheel spacers on, as the rim itself due to 22" was 1/4" from suspension, ran like that for a year but was always uneasy about the clearance. With 20" then the tire would be rubbing the suspension with same specs.
Share This Page
