ATI 15% Underdrive Pulley
crazykid1994
icetraxx
That one looks similar to the one I borrowed from orilies. I used a 1/4 or a 1/2 socket extention for the bar that goes into the bolt hole.
LoadedExpressRam
Gulfport, MS
What did you use to install the actual ATI? Impact wrench or install tool? Im having the hardest time getting this thing on. My impact is only rated for 425lbs so its not cutting it. That or ive got something wrong. Appreciate any feedback you got.
icetraxx
I got it started by hand and a rubber hammer. Made sure it was straight and used my rigid electric impact. I watched it closely and took my time to make sure i didn't mess up the rubber seal. It is only rated for 450lbs and didn't have any issue getting it or back on.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Always lube crank, damper & seal..........anything that has a press fit requires lube........... lube on seal to prevent cutting/tearing.
