atv help...calling all my mechanic buddies!
Discussion in 'The Great Outdoors' started by GlOcKnRaM, Dec 20, 2013.
  1. GlOcKnRaM
    GlOcKnRaM Senior Member
    28
    3,124
    397
    Aug 2, 2012
    Mebane, NC
    Ram Year:
    Engine:
    5.7L V8 Hemi
    Well once again im working on the old beast! Its a 1997 Honda Foreman 400. I went out the other day to start it and it wouldnt turn over. Almost like the battery didnt have enough juice to turn over the stater. I have a video of the noise it makes and if needed Ill upload it, but it just makes a ticking noise coming from the battery and starter. Its seems I have a bad ground somewhere draining the battery or a bad starter?? Before replacing the battery and solenoid we used to have to keep it on a charger for it to start. Replacing these two fixed it for about a month, now its back to the same old problem. Any help would be appreciated, as when it comes to electrical Im a little rusty.
  2. mattman_13
    mattman_13 Senior Member
    31
    1,095
    156
    Oct 21, 2012
    Ram Year:
    Engine:
    I had an issue like that on my streetbike. It would just tick like trying to turn over. Then if I jumped it it would run as normal but then the gauges would stay on even after the key and off button were off. It ended up being A LOT of corrosion on one of the wiring harnesses (took me days going through wiring). Doubt it's something like that The honda 300/400 foremans were beasts. Does it have a pull start or am I going crazy?
    No exaggeration my grandfathers 1989 300 would sit all year with sea foam in the tank you could go outside and kick it a couple of times and ride it like nothing ever changed.
    Maybe try a trickle charger for a few days.
    Goodluck man
  3. NYCruiser
    NYCruiser Senior Member
    2,565
    789
    Dec 17, 2013
    Yonkers, NY
    Ram Year:
    Engine:
    I would check all the wiring, connectors, plugs, etc for corrosion. Get some dielectric grease handy and use it after checking when you reconnect stuff.
    In the meantime, I would install a switch on the battery to make sure I can shut it off when stored.
    GlOcKnRaM likes this.
  4. bmxnick7
    bmxnick7 Member
    71
    13
    Sep 12, 2013
    East haven CT
    Ram Year:
    Engine:
    I just went through an entire rebuild on a foreman 400. Sounds like you have something draining the battery. I have the manual on my computer if you send me your email I can email it to you.
  5. GlOcKnRaM
    28
    3,124
    397
    Aug 2, 2012
    Mebane, NC
    Ram Year:
    Engine:
    5.7L V8 Hemi
    That would be awesome..its [email protected].
    I went to auto zone this morning to test the battery and starter and they were fine! So its got to be something draining the battery, or a short/ bad connection somewhere.
  6. GlOcKnRaM
    28
    3,124
    397
    Aug 2, 2012
    Mebane, NC
    Ram Year:
    Engine:
    5.7L V8 Hemi
    They are beasts! Besides this issue, I can always rely on it! It does have a pull start, and that does work..just takes more pulls than I'd like lol..its easier to just press a button!
  7. Cowboy345
    Cowboy345 Senior Member
    22
    302
    38
    Oct 30, 2012
    Kentucky
    Ram Year:
    Engine:
    its defiantly the wiring. Just check everything maybe a voltmeter would help but you have something draining the battery.... I dout its a short.
Share This Page
