Back up cam reverse tap..
BiGMERF
2017 SLT 4x4
v6
Hey guys qucik question.. i bought this backup camera and i plan to connect it to my pioneer H/U..
Where did you guys tap the reverse? what color was the wire ?
had my daughter holding her in reverse and could not find a live wire here
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
You need to tap into the reverse bulb wire. Then it only comes on when in reverse.
Sent from my LGMP450 using Tapatalk
stimpy433
IOWA
EDITED: look at the diagram on the cover of your 7 pin plug, it's the center pin.
BiGMERF
BiGMERF
2017 SLT 4x4
v6
Sent from my LGMP450 using Tapatalk[/QUOTE]
yea i was trying to avoid getting in there since i know the tow harness has to have a reverse
White wire, look at the diagram on the cover of your 7 pin plug.
looking for it now..i see three white wires.. ive never towed with her, just have an LED ram head in the hitch until i need to
stimpy433
IOWA
I used the white wire in the picture you posted above...should be coming out of the back of the 7 pin plug. It's the center pin on the 7 pin connector. I used it for wiring up my LED bar that has reverse light built in, but should work for you too. Otherwise you could splice off the reverse light bulb wiring behind the taillight.
BiGMERF
BiGMERF
2017 SLT 4x4
v6
ok.... i had a rverse cam prior via a the rear view mirror.. i took that out.. but i remember the guy who put it in tell me he tapped a power line instead cause the reverse bulb wire wasnt giving off enough juice to activate it.. ... i dint understand why it would make a difference, but i figured let me find out which one on the harness is the white..
cant find the diagram you speak of
stimpy433
IOWA
It looks like this.... center pin, the "R" with the light symbol.
stimpy433
IOWA
A little confusing, but glad I could help out.
BiGMERF
BiGMERF
2017 SLT 4x4
v6
of course mines doesnt have it labeled.. sigh lol
bottom says
right stop turn
running lampos
left stop turn
electric brakes
backup lamps
top says
ground
running lamps
left stop turn
right stop turn
stimpy433
IOWA
bottom says
right stop turn
running lampos
left stop turn
electric brakes
backup lamps
top says
ground
running lamps
left stop turn
right stop turn
Bottom cover, center that say "backup lamps" should be the one you want. Yours must be aftermarket add plug set up???
BiGMERF
BiGMERF
2017 SLT 4x4
v6
dood lmao.. im such a damm noob... over here looking for reverse... lmao !!!!!!!!!!
McBroom
Denison Tx
Hemi 6.4L
I'm not 100% sure on the 4 pin plug but I think the white wire is the ground.
Your correct
I Love My 2018 RAM 2500HD 4x4 Off Road. 6.4L. USMC (ret)
BiGMERF
BiGMERF
2017 SLT 4x4
v6
Lil_Ram
Power tech 3.7L
I’m thinking you got it already but I know it’s the purple wire on my 3rd gen for the 7 pin harness
BiGMERF
BiGMERF
2017 SLT 4x4
v6
Actually I’m just going to wire it straight to the reverse on the radio.
Each side of the rca has a red power connection. One side to the camera and one side to the reverse on the radio
