BiGMERF
hey @stimpy433 @McBroom anyonee else does that sounds right?
REAR - camera rca/power connector -> next wire, on one end connect rca and power to camera wire. other side has rca and red/black power wires.. here i used black wire to ground ( tapped into the neg on reverse light ). connected the rca.. However the red POWER i did not connect to a reverse wire.. instead i connected the power to the next wire which is the long rca/power wire...
FRONT - ran that wire through the car to thee front.. then rca to the HU and the power to HU reverse wire
sound right? or was i supposed to do something else in thee rear
the reason im asking is because i am pre installing it before i take her to best buy for the hu install.. so i have no receiver to test right now
i see in this VIDEO the guy hooked up oneee side of thee power to hs reverse on the trailer wiring and then again on the radio.. did i mess up
